LimePSB RPCM v1.4 Board
Introduction
LimePSB RPCM v1.4 Board Key Features
The LimePSB RPCM is carrier board for Raspberry Pi Compute Module 4 or 5 (CM4 or CM5) and mPCIe card (by default LimeSDR XTRX board). LimePSB RPCM carrier board provides a hardware platform for developing and prototyping high-performance designs based on Raspberry Pi CM4 or CM5, RF front end, clock network and mPCIe card. It allows user to use the board in SDR, LoRa and other applications.
Figure 1 LimePSB RPCM v1.4 board top view
Figure 2 LimePSB RPCM v1.4 board bottom view
LimePSB RPCM board features:
Connectors:
Raspberry CM4 and CM5 connector (dual row)
USB 2.0 Type-C socket (USB boot and power delivery)
Dual USB 3.0 (type A) socket and USB header (downstream ports) or Front Panel USB 2.0 header (unpopulated)
Ethernet jack (Gigabit Ethernet with PoE)
mini PCIe x1 Gen 2 (5Gbps)
2x Micro HDMI 2.0 receptacle (up to 4Kp60 supported)
2x 15-pin FPC connectors for MIPI DSI display and CSI camera
3.5 mm 4-pin jack for analog audio and composite video
uSD card socket
Nano-SIM socket
Coaxial RF (4x SMA female + 4x U.FL female) connectors for RF front end
External synchronization (2x SMA female) connectors for input and output
2x Coaxial pass-through U.FL to external SMA connectors
20-pin Raspberry CM4/5 GPIO header (3.3V)
14-pin Raspberry CM4/5 SYS header
5-pin front display connector (power, I2C, button)
Raspberry CM4/5 UART0 header (unpopulated)
2-pin and 4-pin FAN connector (5V default or 3.3V or VCC_INT voltage)
RF front end:
Configuration: MIMO (2x TRX, 2x RX)
LNAs, PAs, RF switches, Couplers, TX power detectors, power (ON/OFF) and mode control (TDD and FDD)
Miscellaneous:
o FPGA Lattice iCE40 Ultra family (iCE5LP4K)
Board temperature sensor
FAN controller
EEPROM
Secure key storage, I/O expander
RTC, ADC
USB 2.0 hub
Configuration dip switch
4x general purpose Dual colour (RG) LEDs
20 pin CM4/5 GPIO header (3.3V)
Front button
Buzzer
GNSS receiver
30.72MHz and 10 MHz (default) on board VCOCXOs and 30.72/38.4/40.00MHz (optional) VCTCXOs
Possibility to tune on board XO by on-board DAC or by phase detector to match a reference clock input (e.g. 10MHz).
Reference clock/PPS input and output SMA connectors (EXT_SYNC_IN and EXT_SYNC_OUT)
Possibility to synchronize multiple boards using coaxial SMA connectors (EXT_SYNC_IN and EXT_SYNC_OUT)
Board power sources:
Barrel (9-14V, 2-3A)
USB Power Delivery (12V 1.5A or 2.5A)
PoE (12V, 2A)
For more information on the following topics, refer to the folowing documents:
Board Overview
he heart of the LimePSB RPCM carrier board is Raspberry PI Compute Module 4 or Compute Module 5 which may be used to transfer digital data between the CM4/5 and mPCIe board while performing data processing. The block diagram for LimePSB RPCM board is as shown in Figure 3.
Figure 3 LimePSB RPCM v1.4 carrier Board Block Diagram
LimePSB RPCM board picture with highlighted connectors and main components are presented in Figure 4 and Figure 5.
Figure 4 LimePSB RPCM v1.4 board top connectors and main components
Figure 5 LimePSB RPCM v1.4 board bottom connectors and main components
Board components are described in the Table 1.
Lattice iCE40 Ultra family (iCE5LP4K) |
FPGA configuration flash (16 MBIT) |
I²C temperature sensor LM75 |
IC8/IC9 |
I²C EEPROM Memory 128Kb (16K x 8), connected to RF transceiver I2C bus |
IC10/IC11 |
I²C secure key storage |
IC14/IC16 |
I²C Real time clock |
IC6 |
8 channel 12 bit ADC |
IC12, IC15 |
I²C I/O expander |
USB2.0 HUB |
IC21, IC26, IC27, IC29, IC30 |
USB switch |
J27, J26 |
2-pin and 4-pin FAN connector (5V default or 3.3V or VCC_INT voltage) |
Configuration, Status, Setup Elements and GPIOs |
LED1, LED2, LED3, LED4 |
User defined indication LED |
LED5 |
Raspberry CM4/5 status |
LED6 |
Green status LED |
Power indication LED |
LED7 |
FPGA status |
BZ1 |
Buzzer |
User defined |
J12 |
Header |
14-pin Raspberry CM4 SYS header |
Header |
Power control and PG status |
Header |
Wireless LAN and Bluetooth control |
J10 |
Header |
20-pin CM4 GPIO header |
J28 |
Header |
FPGA configuration |
DSW1 |
DIP switch |
Boot and USB configuration |
RF front end |
IC52, IC54 |
PA TQP3M9018 |
IC58, IC59 |
LNA SPF5043Z |
IC50, IC51, IC56, IC57 |
RF switch F2972NEGK |
IC53, IC55 |
Coupler HHM22152A2 |
IC72, IC73 |
RF power detector LTC5587 |
J1, J2 |
Connector |
Raspberry Pi CM4(L)/5 connectors |
J11 |
Header |
Raspberry CM4/5 UART0 header (unpopulated) |
Header |
5-pin front screen connector (power, I2C, button) |
J29 |
USB |
USB 2.0 (Type-C) socket |
J33 |
USB |
Dual USB 3.0 (Type-A) socket |
Ethernet |
Gigabit RJ45 (Ethernet with magnetics) port |
J34, J35 |
HDMI |
HDMI 2.0 socket |
J15, J16 |
LVDS |
FPC 15-pin for display and camera |
J14, J17 |
Audio/Video |
3.5 mm jack, Header (unpopulated) |
Micro SD card holder |
Nano-SIM |
Nano-SIM card holder |
Mini PCIe |
Mini PCIe x1 expansion slot |
VCOCXO |
30.72 MHz VCOCXO |
XO6 |
VCOCXO |
10 MHz VCOCXO |
XO2, XO7 |
30.72 MHz VCTCXO |
XO3, XO8 |
30.72 MHz VCTCXO |
XO4, XO9 |
40.00 MHz VCTCXO |
XO5, XO10 |
38.40 MHz VCTCXO |
IC48 |
GNSS receiver |
IC36 (IC38) |
16 (8) bit DAC for XOs VC tuning |
IC47 |
RPi sync mux |
IC31, IC39 |
IC37 |
Phase detector |
J36 |
SMA connector |
Reference clock input EXT_SYNC_IN |
J38 |
SMA connector |
Reference clock output EXT_SYNC_OUT |
J37, J39 |
J20/J22, J23/25, J21, J24 |
Multiple |
Internal U.FL connectors J20/J22, J23/J25 to external SMA J21, J24 |
J41 |
External GNSS antenna |
IC33, IC32, IC35, IC40, IC41, IC42, IC43, IC45 |
Clock signal analog mux |
IC64 |
Switching regulator ADP2386 (3.3V rail) |
IC65 |
Switching regulator ADP2386 (5.0V rail) |
IC66, IC71 |
Linear regulator AP7361-FGE (3.3V rail) |
IC68 |
Linear regulator AP7361-FGE (2.5V rail) |
IC70 |
Linear regulator AP7361-FGE (1.5V rail) |
IC67 |
Linear regulator AP7361-FGE (1.2V rail) |
IC69 |
Voltage reference AS431ANTR-G1 (2.5V rail) |
IC76 |
USB power delivery controller CYPD3177-24LQXQT |
IC74 |
Power over Ethernet controller AG5712-LPB |
LimePSB RPCM Board Architecture
This chapter is dedicated for detailed description of LimePSB RPCM board components and interconnections.
Raspberry CM4/5 Connector
LimePSB RPCM board is designed to use Raspberry Pi CM4/5 as a host computer. Raspberry Pi CM4/5L version without eMMC Flash memory is also supported. Board to board connectors (J1 and J2) are used to connect CM4/5 to the LimePSB RPCM board. Connector pinout, CM4 and CM5 signals and schematic signal names are listed and described in Table 2.
CM4 Pin |
CM4 reference |
Description [1] |
Ground (0V) |
Ground (0V) |
Ethernet_Pair3_P |
ETH_TRD3_P |
Ethernet pair 3 positive |
Ethernet_Pair1_P |
ETH_TRD1_P |
Ethernet pair 1 positive |
Ethernet_Pair3_N |
ETH_TRD3_N |
Ethernet pair 3 negative |
Ethernet_Pair1_N |
ETH_TRD1_N |
Ethernet pair 1 negative |
Ground (0V) |
Ground (0V) |
Ethernet_Pair2_N |
ETH_TRD2_N |
Ethernet pair 2 negative |
Ethernet_Pair0_N |
ETH_TRD0_N |
Ethernet pair 0 negative |
Ethernet_Pair2_P |
ETH_TRD2_P |
Ethernet pair 2 positive |
Ethernet_Pair0_P |
ETH_TRD0_P |
Ethernet pair 0 positive |
Ground (0V) |
Ground (0V) |
Ethernet_nLED3 |
ETH_LED_Y |
Ethernet activity indicator |
Ethernet_SYNC_IN |
RPI_PIN16 |
IEEE1588 SYNC Input |
Ethernet_nLED2 |
ETH_LED_G |
Ethernet speed indicator |
Ethernet_SYNC_OUT |
RPI_PIN18 |
IEEE1588 SYNC Output |
Ethernet_nLED1 |
EEPROM_nWP |
RPI_EEPROM_nWP |
EEPROM write protect |
Pi_nLED_Activity |
RPI_STATUS_LED_R |
Pi activity LED |
Ground (0V) |
Ground (0V) |
GPIO26 |
RFPDB_CONV |
General purpose |
GPIO21 |
RPI_SPI1_SCLK |
General purpose |
GPIO19 |
RPI_SPI1_MISO |
General purpose |
GPIO20 |
RPI_SPI1_MOSI |
General purpose |
RPI_PWM1 |
General purpose |
GPIO16 |
RPI_SPI1_SS2 |
General purpose |
GPIO6 |
RPI_GPIO6 |
General purpose |
GPIO12 |
RPI_PWM0 |
General purpose |
Ground (0V) |
Ground (0V) |
GPIO5 |
BUZZER |
General purpose |
ID_SC |
RPI_ID_SC |
BCM2711 GPIO 1 |
ID_SD |
RPI_ID_SD |
BCM2711 GPIO 0 |
GPIO7 |
RPI_SPI0_SS1 |
General purpose |
GPIO11 |
RPI_SPI0_SCLK |
General purpose |
RPI_SPI0_SS0 |
General purpose |
GPIO9 |
RPI_SPI0_MISO |
General purpose |
GPIO25 |
RFPDA_CONV |
General purpose |
Ground (0V) |
Ground (0V) |
GPIO10 |
RPI_SPI0_MOSI |
General purpose |
GPIO24 |
RPI_BTN1 |
General purpose |
GPIO22 |
RPI_GPIO22 |
General purpose |
GPIO23 |
RPI_BTN2 |
General purpose |
GPIO27 |
RPI_GPIO27 |
General purpose |
GPIO18 |
RPI_SPI1_SS0 |
General purpose |
GPIO17 |
RPI_SPI1_SS1 |
General purpose |
GPIO15 |
RPI_UART0_RX |
General purpose |
Ground (0V) |
Ground (0V) |
GPIO4 |
RPI_GPIO4 |
General purpose |
GPIO14 |
RPI_UART0_TX |
General purpose |
GPIO3 |
RPI_GPIO3 |
General purpose |
SD_CLK |
RPI_SD_CLK |
SD card clock signal |
GPIO2 |
RPI_GPIO2 |
General purpose |
59 |
Ground (0V) |
Ground (0V) |
SD_DAT3 |
RPI_SD_D3 |
SD card/eMMC Data3 signal |
SD_CMD |
RPI_SD_CMD |
SD card/eMMC Command signal |
SD_DAT0 |
RPI_SD_D0 |
SD card/eMMC Data0 signal |
SD_DAT5 |
SD card/eMMC Data5 signal |
Ground (0V) |
Ground (0V) |
SD_DAT1 |
RPI_SD_D1 |
SD card/eMMC Data1 signal |
68 |
SD_DAT4 |
SD card/eMMC Data4 signal |
SD_DAT2 |
RPI_SD_D2 |
SD card/eMMC Data2 signal |
SD_DAT7 |
SD card/eMMC Data7 signal |
Ground (0V) |
SD_DAT6 |
SD card/eMMC Data6 signal |
SD_VDD_Override |
Force SD card/eMMC interface |
Ground (0V) |
SD_PWR_ON |
RPI_SD_PWR_ON |
Output to power-switch for the SD card |
RPI_VBAT |
Do not connect |
77 |
+5V (Input) |
4.75V-5.25V. Main power input |
78 |
GPIO_VREF |
GPIO reference voltage |
79 |
+5V (Input) |
80 |
SCL0 |
RPI_I2C0_SCL |
I2C clock pin |
81 |
+5V (Input) |
82 |
SDA0 |
RPI_I2C0_SDA |
I2C Data pin |
83 |
+5V (Input) |
84 |
CM4_3.3V (Output) |
VCC3P3_RPI |
3.3V ± 2.5%. Power Output |
85 |
+5V (Input) |
86 |
CM4_3.3V (Output) |
VCC3P3_RPI |
87 |
+5V (Input) |
88 |
CM4_1.8V (Output) |
VCC1P8_RPI |
1.8V ± 2.5%. Power Output |
89 |
WL_nDisable |
RPI_WL_nDISABLE |
Wireless interface disable |
90 |
CM4_1.8V (Output) |
VCC1P8_RPI |
91 |
BT_nDisable |
RPI_BT_nDISABLE |
Bluetooth interface disable |
92 |
RUN_PG |
RPI_RUN_PG |
CM4 CPU reset/power good |
93 |
nRPIBOOT |
RPI_nRPIBOOT |
booting from an RPI server |
94 |
AnalogIP1 |
RPI_AIP1 |
Analogue input |
95 |
PI_LED_nPWR |
RPI_LED_nPWR |
Power On LED |
96 |
AnalogIP0 |
RPI_AIP0 |
Analogue input |
97 |
Camera_GPIO |
CAM1_GPIO0 |
Used to shut down the camera |
98 |
Ground (0V) |
99 |
GLOBAL_EN |
RPI_GLOBAL_EN |
CM4 enable |
100 |
nEXTRST |
RPI_nEXTRST |
Output. Driven low during reset |
101 |
USB_OTG_ID |
RPI_USB_OTG_ID |
USB OTG Pin |
102 |
PCIe_CLK_nREQ |
RPI_PCIE_CLK_nREQ |
PCIe clock request |
103 |
USB_N |
RPI_USB_D_N |
USB D- |
104 |
Do not connect |
105 |
USB_P |
RPI_USB_D_P |
USB D+ |
106 |
RPI_PCIE_DET_nWAKE |
Do not connect |
107 |
Ground (0V) |
108 |
Ground (0V) |
109 |
PCIe_nRST |
RPI_PCIE_nRST |
PCIe reset |
110 |
PCIe_CLK_P |
RPI_PCIE_CLK_P |
PCIe clock Out positive |
111 |
VDAC_COMP |
RPI_PIN11 |
Video DAC output |
112 |
PCIe_CLK_N |
RPI_PCIE_CLK_N |
PCIe clock Out negative |
113 |
Ground (0V) |
114 |
Ground (0V) |
115 |
CAM1_D0_N |
CAM1_D0_N |
Input Camera1 D0 negative |
116 |
PCIe_RX_P |
RPI_PCIE_RX_P |
Input PCIe GEN 2 RX positive |
117 |
CAM1_D0_P |
CAM1_D0_P |
Input Camera1 D0 positive |
118 |
PCIe_RX_N |
RPI_PCIE_RX_N |
Input PCIe GEN 2 RX negative |
119 |
Ground (0V) |
120 |
Ground (0V) |
121 |
CAM1_D1_N |
CAM1_D1_N |
Input Camera1 D1 negative |
122 |
PCIe_TX_P |
RPI_PCIE_TX_P |
Output PCIe GEN 2 TX positive |
123 |
CAM1_D1_P |
CAM1_D1_P |
Input Camera1 D1 positive |
124 |
PCIe_TX_N |
RPI_PCIE_TX_N |
125 |
Ground (0V) |
126 |
Ground (0V) |
127 |
CAM1_C_N |
CAM1_CLK_N |
Input Camera1 clock negative |
128 |
CAM0_D0_N |
RPI_USB3_RX0_N |
Input Camera0 D0 negative |
129 |
CAM1_C_P |
CAM1_CLK_P |
Input Camera1 clock positive |
130 |
CAM0_D0_P |
RPI_USB3_RX0_P |
Input Camera0 D0 positive |
131 |
Ground (0V) |
132 |
Ground (0V) |
133 |
CAM1_D2_N |
Input Camera1 D2 negative |
134 |
CAM0_D1_N |
RPI_USB3_D0_P |
Input Camera0 D1 negative |
135 |
CAM1_D2_P |
Input Camera1 D2 positive |
136 |
CAM0_D1_P |
RPI_USB3_D0_N |
Input Camera0 D1 positive |
137 |
Ground (0V) |
138 |
Ground (0V) |
139 |
CAM1_D3_N |
Input Camera1 D3 negative |
140 |
CAM0_C_N |
RPI_USB3_TX0_N |
Input Camera0 clock negative |
141 |
CAM1_D3_P |
Input Camera1 D3 positive |
142 |
CAM0_C_P |
RPI_USB3_TX0_P |
Input Camera0 clock positive |
143 |
HDMI1_HOTPLUG |
HDMI1_HOTPLUG |
Input HDMI1 hotplug |
144 |
Ground (0V) |
145 |
HDMI1_SDA |
HDMI1_SDA |
A Bidirectional HDMI1 SDA |
146 |
HDMI1_TX2_P |
HDMI1_D2_P |
Output HDMI1 TX2 positive |
147 |
HDMI1_SCL |
HDMI1_SCL |
Bidirectional HDMI1 SCL |
148 |
HDMI1_TX2_N |
HDMI1_D2_N |
Output HDMI1 TX2 negative |
149 |
HDMI1_CEC |
HDMI1_CEC |
Input HDMI1 CEC |
150 |
Ground (0V) |
151 |
HDMI0_CEC |
HDMI0_CEC |
Input HDMI0 CEC |
152 |
HDMI1_TX1_P |
HDMI1_D1_P |
Output HDMI1 TX1 positive |
153 |
HDMI0_HOTPLUG |
HDMI0_HPD |
Input HDMI0 hotplug |
154 |
HDMI1_TX1_N |
HDMI1_D1_N |
Output HDMI1 TX1 negative |
155 |
Ground (0V) |
156 |
Ground (0V) |
157 |
DSI0_D0_N |
RPI_USB3_RX1_N |
Output Display0 D0 negative |
158 |
HDMI1_TX0_P |
HDMI1_D0_P |
Output HDMI1 TX0 positive |
159 |
DSI0_D0_P |
RPI_USB3_RX1_P |
Output Display0 D0 positive |
160 |
HDMI1_TX0_N |
HDMI1_D0_N |
Output HDMI1 TX0 negative |
161 |
Ground (0V) |
162 |
Ground (0V) |
163 |
DSI0_D1_N |
RPI_USB3_D1_P |
Output Display0 D1 negative |
164 |
HDMI1_CLK_P |
HDMI1_CLK_P |
Output HDMI1 clock positive |
165 |
DSI0_D1_P |
RPI_USB3_D1_N |
Output Display0 D1 positive |
166 |
HDMI1_CLK_N |
HDMI1_CLK_N |
Output HDMI1 clock negative |
167 |
Ground (0V) |
168 |
Ground (0V) |
169 |
DSI0_C_N |
RPI_USB3_TX1_N |
Output Display0 clock negative |
170 |
HDMI0_TX2_P |
HDMI0_D2_P |
Output HDMI0 TX2 positive |
171 |
DSI0_C_P |
RPI_USB3_TX1_P |
Output Display0 clock positive |
172 |
HDMI0_TX2_N |
HDMI0_D2_N |
Output HDMI0 TX2 negative |
173 |
Ground (0V) |
174 |
Ground (0V) |
175 |
DSI1_D0_N |
DSI1_D0_N |
Output Display1 D0 negative |
176 |
HDMI0_TX1_P |
HDMI0_D1_P |
Output HDMI0 TX1 positive |
177 |
DSI1_D0_P |
DSI1_D0_P |
Output Display1 D0 positive |
178 |
HDMI0_TX1_N |
HDMI0_D1_N |
Output HDMI0 TX1 negative |
179 |
Ground (0V) |
180 |
Ground (0V) |
181 |
DSI1_D1_N |
DSI1_D1_N |
Output Display1 D1 negative |
182 |
HDMI0_TX0_P |
HDMI0_D0_P |
Output HDMI0 TX0 positive |
183 |
DSI1_D1_P |
DSI1_D1_P |
Output Display1 D1 positive |
184 |
HDMI0_TX0_N |
HDMI0_D0_N |
Output HDMI0 TX0 negative |
185 |
Ground (0V) |
186 |
Ground (0V) |
187 |
DSI1_C_N |
DSI1_CLK_N |
Output Display1 clock negative |
188 |
HDMI0_CLK_P |
HDMI0_CLK_P |
Output HDMI0 clock positive |
189 |
DSI1_C_P |
DSI1_CLK_P |
Output Display1 clock positive |
190 |
HDMI0_CLK_N |
HDMI0_CLK_N |
Output HDMI0 clock negative |
191 |
Ground (0V) |
192 |
Ground (0V) |
193 |
DSI1_D2_N |
Output Display1 D2 negative |
194 |
DSI1_D3_N |
Output Display1 D3 negative |
195 |
DSI1_D2_P |
Output Display1 D2 positive |
196 |
DSI1_D3_P |
Output Display1 D3 positive |
197 |
Ground (0V) |
198 |
Ground (0V) |
199 |
HDMI0_SDA |
HDMI0_SDA |
Bidirectional HDMI0 SDA |
200 |
HDMI0_SCL |
HDMI0_SCL |
Bidirectional HDMI0 SCL |
CM4 Pin |
CM4 reference |
Description [2] |
Ground (0V) |
Ground (0V) |
Ethernet_Pair3_P |
ETH_TRD3_P |
Ethernet_Pair1_P |
ETH_TRD1_P |
Ethernet_Pair3_N |
ETH_TRD3_N |
Ethernet_Pair1_N |
ETH_TRD1_N |
Ground (0V) |
Ground (0V) |
Ethernet_Pair2_N |
ETH_TRD2_N |
Ethernet_Pair0_N |
ETH_TRD0_N |
Ethernet_Pair2_P |
ETH_TRD2_P |
Ethernet_Pair0_P |
ETH_TRD0_P |
Ground (0V) |
Ground (0V) |
Ethernet_nLED3 |
ETH_LED_Y |
Fan_Tacho |
RPI_PIN16 |
Fan Tacho Input pin |
Ethernet_nLED2 |
ETH_LED_G |
Ethernet_SYNC_OUT |
RPI_PIN18 |
Fan_PWM |
Open drain output |
EEPROM_nWP |
RPI_EEPROM_nWP |
Pi_nLED_Activity |
RPI_STATUS_LED_R |
Pi activity LED |
Ground (0V) |
Ground (0V) |
GPIO26 |
RFPDB_CONV |
General purpose |
GPIO21 |
RPI_SPI1_SCLK |
General purpose |
GPIO19 |
RPI_SPI1_MISO |
General purpose |
GPIO20 |
RPI_SPI1_MOSI |
General purpose |
RPI_PWM1 |
General purpose |
GPIO16 |
PRI_SPI1_SS2 |
General purpose |
GPIO6 |
RPI_GPIO6 |
General purpose |
GPIO12 |
RPI_PWM0 |
General purpose |
Ground (0V) |
Ground (0V) |
GPIO5 |
BUZZER |
General purpose |
ID_SC |
RPI_ID_SC |
BCM2711 GPIO 1 |
ID_SD |
RPI_ID_SD |
BCM2711 GPIO 0 |
GPIO7 |
RPI_SPI0_SS1 |
General purpose |
GPIO11 |
RPI_SPI0_SCLK |
General purpose |
RPI_SPI0_SS0 |
General purpose |
GPIO9 |
RPI_SPI0_MISO |
General purpose |
GPIO25 |
RFPDA_CONV |
General purpose |
Ground (0V) |
Ground (0V) |
GPIO10 |
RPI_SPI0_MOSI |
General purpose |
GPIO24 |
RPI_BTN1 |
General purpose |
GPIO22 |
RPI_GPIO22 |
General purpose |
GPIO23 |
RPI_BTN2 |
General purpose |
GPIO27 |
RPI_GPIO27 |
General purpose |
GPIO18 |
RPI_SPI1_SS0 |
General purpose |
GPIO17 |
RPI_SPI1_SS1 |
General purpose |
GPIO15 |
RPI_UART0_RX |
General purpose |
Ground (0V) |
Ground (0V) |
GPIO4 |
RPI_GPIO4 |
General purpose |
GPIO14 |
RPI_UART0_TX |
General purpose |
GPIO3 |
RPI_GPIO3 |
General purpose |
SD_CLK |
RPI_SD_CLK |
GPIO2 |
RPI_GPIO2 |
General purpose |
59 |
Ground (0V) |
Ground (0V) |
SD_DAT3 |
RPI_SD_D3 |
SD_CMD |
RPI_SD_CMD |
SD_DAT0 |
RPI_SD_D0 |
SD_DAT5 |
Ground (0V) |
Ground (0V) |
SD_DAT1 |
RPI_SD_D1 |
68 |
SD_DAT4 |
SD_DAT2 |
RPI_SD_D2 |
SD_DAT7 |
Ground (0V) |
SD_DAT6 |
SD_VDD_Override |
Ground (0V) |
SD_PWR_ON |
RPI_SD_PWR_ON |
VBAT |
RPI_VBAT |
RTC Battery input |
77 |
+5V (Input) |
78 |
GPIO_VREF |
79 |
+5V (Input) |
80 |
SCL0 |
RPI_I2C0_SCL |
I2C clock pin |
81 |
+5V (Input) |
82 |
SDA0 |
RPI_I2C0_SDA |
I2C Data pin |
83 |
+5V (Input) |
84 |
CM4_3.3V (Output) |
VCC3P3_RPI |
85 |
+5V (Input) |
86 |
CM4_3.3V (Output) |
VCC3P3_RPI |
87 |
+5V (Input) |
88 |
CM4_1.8V (Output) |
VCC1P8_RPI |
89 |
WL_nDisable |
RPI_WL_nDISABLE |
90 |
CM4_1.8V (Output) |
VCC1P8_RPI |
91 |
BT_nDisable |
RPI_BT_nDISABLE |
92 |
PWR_Button |
RPI_RUN_PG |
CM5 CPU turn on/off |
93 |
nRPIBOOT |
RPI_nRPIBOOT |
94 |
CC1 |
RPI_AIP1 |
USB PSU PD signal |
95 |
LED_nPWR |
RPI_LED_nPWR |
Power On LED |
96 |
CC2 |
RPI_AIP0 |
USB PSU PD signal |
97 |
CAM_GPIO0 |
CAM1_GPIO0 |
98 |
Ground (0V) |
99 |
PMIC_Enable |
RPI_GLOBAL_EN |
CM4 enable |
100 |
CAM_GPIO1 |
RPI_nEXTRST |
101 |
USB_OTG_ID |
RPI_USB_OTG_ID |
USB OTG Pin |
102 |
PCIe_CLK_nREQ |
RPI_PCIE_CLK_nREQ |
103 |
USB_N |
RPI_USB_D_N |
USB D- |
104 |
PCIe_nWAKE |
PCIe WAKE# signal |
105 |
USB_P |
RPI_USB_D_P |
USB D+ |
106 |
PCIe_PWR_EN |
PCIe device enable |
107 |
Ground (0V) |
108 |
Ground (0V) |
109 |
PCIe_nRST |
RPI_PCIE_nRST |
PCIe reset |
110 |
PCIe_CLK_P |
RPI_PCIE_CLK_P |
111 |
VBUS_EN |
RPI_PIN11 |
USB3 power enable |
112 |
PCIe_CLK_N |
RPI_PCIE_CLK_N |
113 |
Ground (0V) |
114 |
Ground (0V) |
115 |
MIPI0_D0_N |
CAM1_D0_N |
Camera / display D0 negative |
116 |
PCIe_RX_P |
RPI_PCIE_RX_P |
117 |
MIPI0_D0_P |
CAM1_D0_P |
Camera / display D0 positive |
118 |
PCIe_RX_N |
RPI_PCIE_RX_N |
119 |
Ground (0V) |
120 |
Ground (0V) |
121 |
MIPI0_D1_N |
CAM1_D1_N |
Camera / display D1 negative |
122 |
PCIe_TX_P |
RPI_PCIE_TX_P |
123 |
MIPI0_D1_P |
CAM1_D1_P |
Camera / display D1 positive |
124 |
PCIe_TX_N |
RPI_PCIE_TX_N |
125 |
Ground (0V) |
126 |
Ground (0V) |
127 |
MIPI0_C_N |
CAM1_CLK_N |
Camera / display clock negative |
128 |
USB3-0-RX_N |
RPI_USB3_RX0_N |
USB3 Port 0 RX Input negative |
129 |
MIPI0_C_P |
CAM1_CLK_P |
Camera / display clock positive |
130 |
USB3-0-RX_P |
RPI_USB3_RX0_P |
USB3 Port 0 RX Input positive |
131 |
Ground (0V) |
132 |
Ground (0V) |
133 |
MIPI0_D2_N |
Camera / display D2 negative |
134 |
USB3-0-DP |
RPI_USB3_D0_P |
USB3 port 0 DP |
135 |
MIPI0_D2_P |
Camera / display D2 positive |
136 |
USB3-0-DM |
RPI_USB3_D0_N |
USB3 Port 0 DM |
137 |
Ground (0V) |
138 |
Ground (0V) |
139 |
MIPI0_D3_N |
Camera / display D3 negative |
140 |
USB3-0-TX_N |
RPI_USB3_TX0_N |
USB3 Port 0 TX output negative |
141 |
MIPI0_D3_P |
Camera / display D3 positive |
142 |
USB3-0-TX_P |
RPI_USB3_TX0_P |
USB3 Port 0 TX output positive |
143 |
HDMI1_HOTPLUG |
HDMI1_HOTPLUG |
144 |
Ground (0V) |
145 |
HDMI1_SDA |
HDMI1_SDA |
146 |
HDMI1_TX2_P |
HDMI1_D2_P |
147 |
HDMI1_SCL |
HDMI1_SCL |
148 |
HDMI1_TX2_N |
HDMI1_D2_N |
149 |
HDMI1_CEC |
HDMI1_CEC |
Input HDMI1 CEC |
150 |
Ground (0V) |
151 |
HDMI0_CEC |
HDMI0_CEC |
Input HDMI0 CEC |
152 |
HDMI1_TX1_P |
HDMI1_D1_P |
153 |
HDMI0_HOTPLUG |
HDMI0_HPD |
154 |
HDMI1_TX1_N |
HDMI1_D1_N |
155 |
Ground (0V) |
156 |
Ground (0V) |
157 |
USB3-1-RX_N |
RPI_USB3_RX1_N |
USB3 Port 1 RX Input negative |
158 |
HDMI1_TX0_P |
HDMI1_D0_P |
159 |
USB3-1-RX_P |
RPI_USB3_RX1_P |
USB3 Port 1 RX Input positive |
160 |
HDMI1_TX0_N |
HDMI1_D0_N |
161 |
Ground (0V) |
162 |
Ground (0V) |
163 |
USB3-1-DP |
RPI_USB3_D1_P |
USB3 port 1 DP |
164 |
HDMI1_CLK_P |
HDMI1_CLK_P |
165 |
USB3-1-DM |
RPI_USB3_D1_N |
USB3 Port 1 DM |
166 |
HDMI1_CLK_N |
HDMI1_CLK_N |
167 |
Ground (0V) |
168 |
Ground (0V) |
169 |
USB3-1-TX_N |
RPI_USB3_TX1_N |
USB3 Port 1 TX output negative |
170 |
HDMI0_TX2_P |
HDMI0_D2_P |
171 |
USB3-1-TX_P |
RPI_USB3_TX1_P |
USB3 Port 1 TX output positive |
172 |
HDMI0_TX2_N |
HDMI0_D2_N |
173 |
Ground (0V) |
174 |
Ground (0V) |
175 |
MIPI1_D0_N |
DSI1_D0_N |
176 |
HDMI0_TX1_P |
HDMI0_D1_P |
177 |
MIPI1_D0_P |
DSI1_D0_P |
178 |
HDMI0_TX1_N |
HDMI0_D1_N |
179 |
Ground (0V) |
180 |
Ground (0V) |
181 |
MIPI1_D1_N |
DSI1_D1_N |
182 |
HDMI0_TX0_P |
HDMI0_D0_P |
183 |
MIPI1_D1_P |
DSI1_D1_P |
184 |
HDMI0_TX0_N |
HDMI0_D0_N |
185 |
Ground (0V) |
186 |
Ground (0V) |
187 |
MIPI1_C_N |
DSI1_CLK_N |
188 |
HDMI0_CLK_P |
HDMI0_CLK_P |
189 |
MIPI1_C_P |
DSI1_CLK_P |
190 |
HDMI0_CLK_N |
HDMI0_CLK_N |
191 |
Ground (0V) |
192 |
Ground (0V) |
193 |
MIPI1_D2_N |
194 |
MIPI1_D3_N |
195 |
MIPI1_D2_P |
196 |
MIPI1_D3_P |
197 |
Ground (0V) |
198 |
Ground (0V) |
199 |
HDMI0_SDA |
HDMI0_SDA |
200 |
HDMI0_SCL |
HDMI0_SCL |
LimePSB RPCM board has several headers and a DIP switch dedicated for Raspberry Pi CM4/5 configuration, debug, analog inputs or other purposes. SYS Header (J12) pins, schematic signal names and description are given in Table 3.
Description [1], [2] |
Ground (0V) |
RPI_nRPIBOOT |
A low on this pin forces CM4/5 booting. To enable Raspberry Pi USB boot also place nRPIBOOT jumper on J12 pins 1-2. Place jumper on header J26 to switch Raspberry Pi USB from USB hub to USB C connector. |
Ground (0V) |
RPI_EEPROM_nWP |
CM4/5 on-board EEPROM write protect |
RPI_AIP0 |
Analogue input (CM4) / USB CC1 (CM5) |
RPI_AIP1 |
Analogue input (CM4) / USB CC2 (CM5) |
Ground (0V) |
RPI_SYNC_IN |
RPI_SYNC_OUT |
RPI_RUN_PG |
RUN_PG pin when high signals that the CM4/5 has started. Driving this pin low resets the module. |
RPI_PIN11 |
Video DAC output (CM4) / USB3 VBUS enable (CM5) |
Ground (0V) |
RPI_RUN_PG_BUFF |
Buffered (5V output) RPI_RUN_PG line. High signal indicates CM4 CPU is running. / Power button for CM5. |
RPI_GLOBAL_EN |
Drive low to power off CM4/5. A button between pins 13-14 can be used to wake up compute module from power down. |
Description of power control header J5 (not fitted) for Raspberry Pi CM4/5 pinout is given in Table 4.
RPI_GLOBAL_EN |
Drive low to power off CM4/5. |
Ground (0V) |
RPI_RUN_PG |
Drive low to reset CM4/5 CPU/high signal indicates CM4/5 CPU is running. |
Raspberry Pi Compute Module 4/5 on board WiFi and Bluetooth disable signals may be controlled from header J6 (not fitted) as shown in Table 5.
RPI_WL_nDISABLE |
This pin serves a number of functions: It can be used to monitor the enable/disable state of wireless networking. A logic high means the WIFI module is powered up. When driven or tied low it prevents the wireless network module from powering up. This is useful to reduce power consumption or in applications where it is required to physically ensure the wireless networking is disabled. If the interface is enabled after being disabled, the wireless interface driver needs reinitialised. |
Ground (0V) |
RPI_BT_nDISABLE |
This pin serves a number of functions: It can be used to monitor the enable/disable state of Bluetooth. A logic high means the Bluetooth module is powered up. When driven, or tied low, it prevents the Bluetooth module from powering up. This is useful to reduce power consumption, or in applications where it is required to physically ensure the Bluetooth is disabled. If the interface is enabled after being disabled, the Bluetooth interface driver needs reinitialised. |
DIP Switch configuration
Some configuration can be done by switching SW1 DIP switch bits. Detailed switch bit descriptions is given in Table 6.
Bit |
RPI_nRPIBOOT |
RPi boot source: OFF: RPI boots from eMMC/uSD (default). ON: Booting from eMMC will be stopped and booting will be transferred to RPi boot which is via USB. |
USB_C_RPI1 |
RPi USB 2.0 port mux control: OFF: RPi USB is connected to USB hub (default). ON: RPi USB is connected to USB C connector. |
USB_PD_I |
USB C PD current configuration: OFF: I=2.5A (default). ON: I=1.5A. |
EN_CM5_USB3 |
Dual USB socket source: OFF: connected to USB 2.0 hub (for CM4). ON: connected to CM5 USB3.0 lines (for CM5). |
FPGA configuration
LimePSB RPCM board houses Lattice Semiconductor ICE40 Ultra family FPGA ICE5LP4K. It can be copnfigured by RPI CM4/5 (RPI_SPI0) or by external source (JTAG). By default FPGA is set to SPI slave mode and PRi module is in master mode to configure it during boot up. Also FPGA can be set to SPI master mode (FPGA_CFG) while CM4/5 (RPI_SPI0) is disconnected. In this case FPGA configuration information is stored in flash IC19 (NF). Hardware configuration for both modes are shown table 7.
Component id |
Slave SPI |
Master SPI |
R113 |
populate |
populate |
R114 |
remove |
populate |
R115 |
populate |
remove |
R116 |
remove |
populate |
R118 |
populate |
remove |
R119 |
populate |
populate |
R120 |
populate |
remove |
R122 |
remove |
populate |
R124 |
remove |
populate |
remove |
populate |
C63 |
remove |
populate |
Mini PCIe x1 Socket
LimePSB RPCM board features mini PCIe x1 specification compatible socket. LimePSB RPCM board mPCIe socket is also compatible with some non-standard expansion boards like LimeSDR-XTRX, LoRaWAN and LoRa Core. More detailed information is listed in Table 8.
Mini PCIe x1 specification reference [3] |
LimePSB-RPCM schematic signal name |
XTRX Reference [4] |
LoRaWAN reference [5] |
SX1302/03 Corecell schematic signal name [6] |
RPI_PCIE_DET_nWAKE (NC) |
VCC3P3_MPCIE |
VCC |
VCC5V_IN |
PCIE_COEX1 |
PCIE_COEX2 |
PPS_IN |
VCC1P5 |
GPIO(6) (NC) |
RPI_PCIE_CLK_nREQ |
CLK_REQUEST# |
UIM_PWR |
UIM_VCC |
UIM_DIO |
SWDIO |
RPI_PCIE_CLK_N |
PCIE_REF_CLK_N |
SWCLK |
RPI_PCIE_CLK_P |
PCIE_REF_CLK_P |
UIM_RST |
BOOT0 |
POWER_EN(NC) |
PCIE_UIM8 |
HOST_SCK (NC) |
PCIE_UIMC4 (NC) |
PCIE_CLK_IN |
HOST_MISO(NC) |
nDISABLE |
RPI_PCIE_nRST |
PCIE_PERST# |
nRESET |
SX1302_RESET_HOST (NC) |
RPI_PCIE_RX_N |
PCIE_TX0_N |
HOST_MOSI(NC) |
VCC |
SX1261_BUSY (NC) |
RPI_PCIE_RX_P |
PCIE_TX0_P |
HOST_CSN (NC) |
VCC1P5 |
SX1302_GPIO_8 (NC) |
PCIE_SMB_CLK |
LMK_CLKOUT4/GPIO8 |
I2C_SCL (NC) |
PCIE_PET0_N |
PCIE_RX0_N |
PPS |
PCIE_SMB_DATA |
LMK_CLKOUT4/GPIO8 |
I2C_SDA (NC) |
PCIE_PET0_P |
PCIE_RX0_P |
PCIE_USB_N |
USB_D_N |
USB_D- / Tx |
USB_DM |
PCIE_USB_P |
USB_D_P |
USB_D+ / Rx |
USB_DP |
PCIE_TX1_N (NC) |
VCC |
VCC3V3_IN |
PCIE_TX1_P (NC) |
VCC |
VCC3V3_IN |
PCIE_LED_WWAN |
nTX |
PCIE_LED_WLAN |
nRX |
SX1261_NSS (NC) |
JTCK-SWCLK (NC) |
PCIE_LED_WPAN |
SX1261_DIO1 (NC) |
PCIE_RX1_N (NC) |
JTMS-SWDIO (NC) |
VCC1P5 |
SX1261_NRESET(NC) |
PCIE_RX1_P (NC) |
MCU_NRESET (NC) |
PCIE_W_DISABLE2# (NC) |
MCU_BOOT0 (NC) |
VCC3P3_MPCIE |
VCC |
VCC3V3_IN |
RF Front End
LimePSB RPCM RF path features power amplifiers, low noise amplifiers, SPDT switches, Couplers and power detectors as shown in Figure 6.
Figure 6 LimePSB RPCM v1.4 RFFE diagram
A single control signal (RF_SW_TDD) is used to control all RF switches simultaneously for both A and B channels to change between TDD and FDD modes as shown in Table 9.
Control signal (RF_SW_TDD) |
TRXA/B connected to |
High |
TXA/B_IN |
RXA/B_OUT |
Low |
RXA/B_OUT |
By default RF switches may be controlled from FPGA pin 13 (via resistor R43). Optional control source may be RFFE TDD control header (J18).
RF path contains two types of connectors: board edge SMA connectors (J42, J43, J46, J47) used for external connections (antennas or cables) and U.FL connectors (J44, J45, J48, 49) used for internal connections (for example to connect to XTRX mini PCIe expansion board).
Signal frequency range of TX and RX paths are listed in Table 10.
Direction |
TX |
100 MHz - 4 GHz |
RX |
100 MHz - 4 GHz |
More detailed RF path component parameters are given in Table 11.
Function |
Gain, dB |
Output P1dB, dBm |
NF, dB |
TQP3M9018 |
TX amplifier |
24.6dB (900 MHz) |
22.3dBm (900 MHz) |
0.9dB (900 MHz) |
22dB (1900 MHz) |
22dBm (1950 MHz) |
1.3dB (1950 MHz) |
18.3dB (4000 MHz) |
14.7dBm (4000 MHz) |
2.4dB (4000 MHz) |
SPF5043Z |
RX amplifier |
18.2dB (900 MHz) |
22.6dBm (900 MHz) |
0.8dB (900 MHz) |
12.9dB (1960 MHz) |
22.7dBm (1900 MHz) |
0.8dB (1900 MHz) |
7.0dB (3800 MHz) |
22.8dBm (3800 MHz) |
1.5dB (3800 MHz) |
F2972NEGK |
RF switch |
-0.53dB (1000 MHz) |
38dBm (1800 MHz) |
-0.4dB (2000 MHz) |
-0.55B (6000 MHz) |
Both channels TX PAs TQP3M9018 outputs are coupled by HHM22152A2 (IC53, IC55) to RF power detectors LTC5587 (IC72, IC73). Power detector is connected to RPi CM4/5 SPI (RPI_SPI0). To enable it drive GPPIO expanders EXP1 GPB3 pin high. Information about LTC5587 is available in datasheet. URL: https://www.analog.com/en/products/ltc5587.html
USB Subsystem
LimePSB RPCM contains USB2.0 hub, over current protection, type-C, double type-A sockets and headers. The USB subsystem diagram is as shown in Figure 7.
Figure 7 LimePSB RPCM v1.4 USB subsystem diagram
Main LimePSB RPCM board USB subsystem components:
USB type-C socket (J29) is primarily used as one of power supply sources (for more information check section 2.15 Power Distribution). Also it is used to boot CM4/5. To enable RPi USB boot change configuration dip switch (DSW1) bits 1 and 2 to on positions.
USB type-A dual socket (J33) may be used to connect USB peripherals to the Raspberry Pi CM4/5. Top socket is USB 3.0 if CM5 is used.
USB type-A dual socket (J33) and header (J31) have over current protection. Current limit is set to 600 mA. Both sockets share same protection circuitry so if one of them tries to draw more current both sockets will be disabled. Header has it is own separate over current protection.
USB2.0 hub USB2517 (IC20) USB 2.0 hub expands Raspberry Pi CM4/5 USB port to dual USB socket (J33), header (J31) and mPCIe (J3). For more information check Table 12.
Pin name |
Function [7] |
59/58 |
USBUP_DP/ USBUP_DM |
Root port |
USB_HUB_D0_P/ USB_HUB_D0_N |
Connected to CM4/5 USB via USB switch |
2/1 |
USBDN1_DP/ USBDN1_DM |
Downstream port |
USB_HUB_D1_P/ USB_HUB_D1_N |
J3 (mPCIe) |
4/3 |
USBDN2_DP/ USBDN2_DM |
Downstream port |
USB_HUB_D2_P/ USB_HUB_D2_N |
J33 (USB type-A top socket) |
7/6 |
USBDN3_DP/ USBDN3_DM |
Downstream port |
USB_HUB_D3_P/ USB_HUB_D3_N |
J31 (USB header pins 3/5) |
9/8 |
USBDN4_DP/ USBDN4_DM |
Downstream port |
USB_HUB_D4_P/ USB_HUB_D4_N |
J33 (USB type-A bottom socket) |
12/11 |
USBDN5_DP/ USBDN5_DM |
Downstream port |
USB_HUB_D5_P/ USB_HUB_D5_N |
J31 (USB header pinspins 2/4) |
54/53 |
USBDN6_DP/ USBDN6_DM |
Downstream port |
USB_HUB_D6_P/ USB_HUB_D5_N |
IC48 (GNSS) |
56/55 |
USBDN7_DP/ USBDN7_DM |
Downstream port |
User Interface Components
LimePSB RPCM board features button, buzzer, 6 dual colour (red and green (RG)) LEDs, 1 green indication LED, and 2 Ethernet activity LEDs (yellow and green). All board user interface components are highlighted in Figure 8.
Figure 8. LimePSB RPCM v1.4 user interface components
Dual color LEDs (LED1-LED4) are connected to I/O expander (IC12). Their function may be programmed according to the user requirements. Dual color LED5 indicates Raspberry Pi status, LED7 indicates FPGA configuration status. Green LED6 indicates board power. These LEDs are mounted on the front side of the board.
Ethernet connector J9 has two LEDs: yellow and green. LEDs indicate wired network activity and speed.
Default LEDs function and related information is listed in Table 13.
I/O expander (IC13) pin |
RPI_LED1_R |
GPA0 |
User defined. |
RPI_LED1_G |
GPA1 |
RPI_LED2_R |
GPA2 |
User defined. |
RPI_LED2_G |
GPA3 |
RPI_LED3_R |
GPA4 |
User defined. |
RPI_LED3_G |
GPA5 |
LED4 |
RPI_LED4_R |
GPA6 |
User defined. |
RPI_LED4_G |
GPA7 |
LED5 |
RPI_STATUS_LED_R |
Green is connected to CM4/5 PI_LED_nPWR (Power On) and red is connected to Pi_nLED_Activity (Activity) |
RPI_STATUS_LED_G |
LED6 |
Board power. Connected to 3.3 V power rail. |
LED7 |
FPGA_LED_R |
User defined Indictes FPGA configuration status |
FPGA_CDONE |
Ethernet connector J9 LEDs |
ETH_LED_Y |
Green is connected to Ethernet_nLED2 (Ethernet speed indicator: 1Gbit or 100Mbit Link) and yellow is connected to Ethernet_nLED3 (Ethernet activity indicator). |
ETH_LED_G |
A user button (BTN1) and buzzer (BZ1) are mounted on the front side of the board and can be used for various purposes. The button is connected to Raspberry Pi CM4/5 GPIO24 (default)/CM5 RUN_PG, has external pull up resistors and is hardware debounced. Buzzer control circuit is connected to GPIO5.
SPI, I2C, UART Interfaces
LimePSB-RPCM features multiple low speed interfaces like SPI, I2C, UART. LimePSB-RPCM low speed interfaces signal names, I/O standards are listed in table 14.
Interface |
CM4/5 pin |
SPI0 |
RPI_SPI0_SCLK |
38 (GPIO11) |
Serial Clock (CM4/5 output) |
RPI_SPI0_MOSI |
44 (GPIO10) |
Data (CM4/5 output) |
RPI_SPI0_MISO |
40 (GPIO9) |
Data (CM4/5 input) |
RPI_SPI0_SS0 |
39 (GPIO8) |
IC18 FPGA config SPI slave select (CM4/5 output) |
RPI_SPI0_SS1 |
37 (GPIO7) |
IC37 phase detector SPI slave select (CM4/5 output) |
RFPDA_CONV |
41 (GPIO25) |
IC72 RF power detector SPI slave select (CM4/5 output) |
RFPDB_CONV |
24 (GPIO26) |
IC73 RF power detector SPI slave select (CM4/5 output) |
SPI1 |
RPI_SPI1_SCLK |
25 (GPIO21) |
RPI_SPI1_MOSI |
27 (GPIO20) |
RPI_SPI1_MISO |
26 (GPIO19) |
RPI_SPI1_SS0 |
49 (GPIO18) |
IC6 ADC SPI slave select (CM4/5 output) |
RPI_SPI1_SS1 |
50 (GPIO17) |
IC18 FPGA SPI slave select (CM4/5 output) |
RPI_SPI1_SS2 |
29 (GPIO16) |
I2C0 |
RPI_I2C0_SCL |
80 |
RPI_I2C0_SDA |
82 |
Data (CM4/5 input/output) |
UART0 |
RPI_UART0_RX |
51 (GPIO15) |
RPI_UART0_TX |
55 (GPIO14) |
FPGA low speed interfaces signal names, I/O standards are listed in table 15.
Interface |
CFG |
FPGA_CFG_SCK |
15 (IOB_34A) |
FPGA_CFG_SO |
14 (IOB_32A) |
FPGA configuration flash Data (FPGA input) |
FPGA_CFG_SI |
17 (IOB_33B) |
FPGA configuration flash Data (FPGA output) |
FPGA_CFG_CSN |
16 (IOB_35B) |
FPGA SPI slave select (FPGA input) |
SPI0 |
FPGA_SPI0_SCLK |
43 (IOT_49A) |
FPGA_SPI0_MOSI |
38 (IOT_50B) |
FPGA_SPI0_DAC_SS |
42 (IOT_51A) |
IC36/IC38 DAC SPI slave select (FPGA output) |
I2C0 |
FPGA_I2C0_SCL |
47 (IOB_2A) |
FPGA_I2C0_SDA |
48 (IOB_4A) |
Data (FPGA input/output) |
UART |
GNSS_UART_RX |
51 (GPIO15) |
GNSS_UART_TX |
55 (GPIO14) |
RPI_I2C0 (FPGA_I2C0) interface devices, addresses and other info are shown in table 16.
RPI_I2C0 slave device |
1 0 0 1 0 0 0 R/W |
IC8(default)/IC9 |
1 0 1 0 0 0 0 R/W |
CAT24C128WI-GT3/M24128 |
IC10/IC11 |
Secure key storage |
1 1 0 0 0 0 0 R/W |
ATECC508A |
IC14/IC16 |
RTC |
1 0 1 0 0 0 1 R/W |
PCF85063AT |
FAN controller |
0 1 0 1 1 1 1 R/W |
EMC2301 |
IC76 |
USB PD controller |
0 0 0 1 0 0 0 R/W |
CYPD3177-24LQXQT |
IC12 |
I/O expander |
0 1 0 0 0 0 0 R/W |
MCP23017-E/ML |
IC15 |
I/O expander |
0 1 0 0 0 0 1 R/W |
MCP23017-E/ML |
USB2.0 hub |
0 1 0 1 1 0 0 R/W |
USB2517 (disabled) |
Front Display Connector
LimePSB RPCM board has 5-pin 0.1” pitch header J8 with friction lock (Molex 0022112052 [8]) dedicated for front screen connection. Front display connector J8 contains signals for I2C interface, button and power rail. More detailed information about the front display connector is provided in table 17.
J8 pin |
Ground (0V) |
VCC3P3/VCC5P0 |
Power 3.3V (default) or 5V |
RPI_ID_SD |
I2C data |
RPI_ID_SC |
I2C clock |
RPI_BTN2 |
User button 2 (debounced) |
MIPI DSI Display and CSI Camera Connectors
LimePSB-RPCM has two 15-pin FPC connectors for MIPI DSI display and MIPI CSI camera. MIPI DSI interface is used for connecting serial display. Detailed display 1 connector J15 pinout is as shown in table 18.
Ground (0V) |
DSI1_D1_N |
DSI1_D1_P |
Ground (0V) |
DSI1_CLK_N |
DSI1_CLK_P |
Ground (0V) |
DSI1_D0_N |
DSI1_D0_P |
Ground (0V) |
RPI_I2C0_SCL |
I2C clock |
RPI_I2C0_SDA |
I2C data |
Ground (0V) |
3.3V power rail |
3.3V power rail |
MIPI CSI interface is used for serial camera. Detail camera 1 connector J16 pinout is as shown in table 19.
Ground (0V) |
CAM1_D0_N |
CAM1_D0_P |
Ground (0V) |
CAM1_D1_N |
CAM1_D1_P |
Ground (0V) |
CAM1_CLK_N |
CAM1_CLK_P |
Ground (0V) |
CAM1_GPIO0 |
Typically used to shut down the camera |
CAM1_GPIO1 |
RPI_I2C0_SCL |
I2C clock |
RPI_I2C0_SDA |
I2C data |
3.3V power rail |
HMDI, Ethernet Connectors and uSD Socket
LimePSB-RPCM board features 2 Micro (type D) HDMI 2.0 sockets (J34 and J35). Data signals are directly connected between Raspberry Pi CM4/5 TMDS interfaces and HDMI connectors. 5V power for HDMI connectors is supplied via a current-limited (600 mA) switch (IC28).
LimePSB-RPCM board also features Gigabit Ethernet and power over Ethernet (PoE) capable RJ45 connector (J9).
For Raspberry Pi CM4/5L module (Raspberry Pi CM4/5 without eMMC Flash memory) micro SD card push-push socket (J7) must be used along with the appropriate uSD card.
GPIO Connector
Some Raspberry Pi Compute Module 4/5 and FPGA GPIOs are connected to 20 pin 0.1” J10 header. Several pins of this connector are dedicated for power (1 pin for 3.3 V and 2 pins for 5V). GPIO header pins (J10) and additional information is given in table 20.
CM4/5 pin |
3.3V power rail |
5.0V power rail |
RPI_GPIO22 |
GPIO22 |
General purpose |
5.0V power rail |
RPI_GPIO27 |
GPIO27 |
General purpose |
RPI_GPIO3 |
GPIO3 |
General purpose |
RPI_GPIO6 |
GPIO6 |
General purpose |
RPI_UART0_TX |
GPIO14 |
General purpose configured as UART output |
RPI_SPI0_MOSI |
GPIO10 |
General purpose configured as SPI output |
RPI_UART0_RX |
GPIO15 |
General purpose configured as UART input |
RPI_SPI0_MISO |
GPIO9 |
General purpose configured as SPI input |
FPGA_GPIO0 |
FPGA 45 pin (IOB_5B) |
RPI_SPI0_SCLK |
GPIO11 |
General purpose configured as SPI clock |
FPGA_GPIO1 |
FPGA 21 pin (IOB_23B) |
RPI_GPIO2 |
GPIO2 |
General purpose |
RPI_GPIO4 |
GPIO4 |
General purpose |
RPI_ID_SD |
ID_SD |
I2C interface SDfor HATs (ID EEPROM) |
RPI_ID_SC |
ID_SC |
I2C interface SC for HATs (ID EEPROM) |
Ground (0V) |
Ground (0V) |
Board Temperature Control
LimePSB-RPCM board has two dedicated 0.1” pitch headers J26 and J27 for fans. Header J26 is standard 4-pin fan header while J27 is 2-pin header. Fan control voltage is VCC_IN (12V) by default, but it may be changed to 3.3V or 5V by resistors. Fan power may be controlled from I/O expander (EXP0) output GPB7 (FAN_CTRL), directly from temperature sensor IC7 pin 3 (LM75_OS) or by FAN controller (IC13) (default).
4 pin FAN connector (J26) is compatible with 3 pin fans. PWM signal from FAN controller (IC13) can be used to control fan speed by switching MOSFET (VT2) if R92 is fitted (default). If 4 pin fan is used remove R92 and fit R83 to route PWM signal to the connectors 4th pin.
Clock Distribution Network
LimePSB-RPCM board clock network comprises of on-board voltage controlled crystal oscillators, phase detector, clock buffers, GNSS receiver, clock source selection analog muxes, reference clock input and output connectors. Board clock distribution block diagram is as shown in figure 9.
Figure 9. LimePSB RPCM v1.4 board clock distribution block diagram
LimePSB-RPCM board distributes reference clock to and from Raspberry Pi Compute Module 4/5, mini PCIe connector and external sources. Clock and PPS signals can be sourced from on board XOs and GNSS transceiver or another external source via J36 (EXT_SYNC_IN) connector. Also J38 (EXT_SYNC_OUT) connector can be used as clock signal output thus synchronizing multiple systems. Clock path may be configured using analog muxes that are controlled by CM4/5 module as described in table 21.
Schematic ID |
Input signal |
Output signal |
CM4/5 pin |
IC33 |
EXT_SYNC_IN |
ADF_REFIN |
EXP1 GPA3 |
Phase detector (IC34) input selection |
LMK10_CLK_OUT2 |
IC43 |
SYNC_OUT |
PCIE_PPS_IN |
EXP1 GPA7 |
PPS signal source selection for mPCIe expansion boards |
EXT_SYNC_IN |
IC41 |
EXT_SYNC_IN |
RPI_SYNC_IN |
EXP1 GPA4 |
CM4/5 SYNC_IN synchronization input source selection |
PCIE_PPS_OUT |
IC45 |
EXT_SYNC_IN |
PCIE_UIMC4 |
EXP1 GPA5 |
Reference clock selection for mPCIE exanpsion board (XTRX) |
LMKRF_CLK_OUT2 |
IC32 |
SYNC_OUT |
EXT_SYNC_OUT |
EXP1 GPA0 EXP1 GPA1 EXP1 GPA2 |
Synchronization output signal selection |
PCIE_PPS_OUT |
LMKRF_CLK_OUT3 |
LMK10_CLK_OUT3 |
IC42 |
RPI_SYNC_OUT |
SYNC_OUT |
EXP0 GPB5 |
PPS signal source selection |
FPGA_SYNC_OUT |
IC40 |
PCIE_COEX2 |
PCIE_PPS_OUT |
EXP1 GPA6 |
PPS signal input from mPCIE expansion board (XTRX) Clock signal input from mPCIE expansion board (XTRX) |
PCIE_SMB_CLK |
R3 |
PCIE_PPS_IN |
PCIE_COEX1 |
PPS signal output for mPCIE expansion board (XTRX) |
R5 |
PCIE_PPS_IN |
PCIE_PETn0 |
PPS signal output for mPCIE expansion board (LoRa Semtech) |
R4 |
PCIE_PPS_IN |
PCIE_COEX2 |
PPS signal output for mPCIE expansion board (LoRa n-Fuse)/PPS output for (XTRX) |
LimePSB-RPCM board has several on-board crystal oscillator (XO) options that may be used as source for clock buffers (LMK00101). By default voltage controlled oven compensated crystal oscillators (VCOCXO) XO1 and XO6 are populated. Optional voltage controlled temperature compensated crystal oscillators XO2 – XO5 and XO7 – XO10 (VCTCXO) are not populated by default. All these XOs may be tuned by DAC (16-bit IC36 default or 8-bit IC38) or phase detector (IC37). Clock network components are listed in table 22.
Designator |
Function |
Part number |
Parameters |
VCOCXO |
U7475LF 30.72MHz |
30.72 MHz |
XO6 |
VCOCXO |
U8073LF 10.0MHz |
10 HMz |
XO2, XO7 |
E6245LF 30.72 MHz |
30.72 MHz |
Not mounted |
XO3, XO8 |
E5280LF 30.72MHz |
30.72 MHz |
Not mounted |
XO4,XO9 |
RTX5032A, 40.00MHz |
40 MHz |
Not mounted |
XO5, XO10 |
ASVTX-12-A-38.400MHZ-H10-T |
38.4 MHz |
Not mounted |
IC36 |
DAC |
AD5662 |
16 Bit |
IC38 |
AD5601BKSZ-REEL7 |
8 Bit |
Not mounted |
IC31, IC39 |
LMK00105SQ/NOPB |
IC37 |
Phase detector |
ADF4002BCPZ-RL7 |
IC48 |
GNSS receiver |
NEO-M8Q |
RPI_SYNC mux (IC47) is needed for CM4 and CM5 compatibility purposes.
Power Distribution
LimePSB RPCM board power delivery network consists of different power rails with different regulators, voltages and filters. LimePSB RPCM board power distribution block diagram is presented in Figure 10.
Figure 10 LimePSB RPCM v1.4 board power distribution block diagram
LimePSB RPCM board may be supplied from USB Type-C port (USB Power delivery), Ethernet RJ45 port (PoE) or barrel DC connector (9-14V):
USB Type-C socket (9-12V 2.5 A or 1.5 A) may be used to supply LimePSB RPCM board. In this case make sure that USB Power Delivery 18W or more power adapter is used. Depending on application board requested current from source may be lowered from 2.5A to 1.5A by changing configuration dip switch (DSW1) bit 3 to ON position.
RJ45 socket is an alternative way to supply the LimePSB RPCM board. Make sure PoE+ (802.3at) class 4 compliant power source is used.
Barrel connector (9-14V 2A) also may be used to power LimePSB RPCM board.
To keep on board RTC running and enable GNSS hardware backup mode when board power is disconnected lithium coin cell 3V CR1220 battery must be inserted into BATT1 battery holder.
References
Raspberry Pi, Compute Module 4 datasheet. URL: https://datasheets.raspberrypi.com/cm4/cm4-datasheet.pdf
Raspberry Pi, Compute Module 5 datasheet. URL: https://datasheets.raspberrypi.com/cm5/cm5-datasheet.pdf
PCI Express Mini Card Electromechanical Specification Revision 1.2. URL: https://pcisig.com/specifications/
Lime Microsystems, LimeSDR-XTRX. URL: https://github.com/myriadrf/LimeSDR-XTRX
n-fuse, Concentrator Card LRWCCx-MPCIE for LoRaWAN technology. URL: https://www.n-fuse.co/devices/LoRaWAN-Concentrator-Card-mini-PCIe.html
Semtech, SX1303CTSXXXGW1, LoRa Corecell Gateway Reference Design for Fine Timestamp Based on SX1303 for LoRa Core. URL: https://www.semtech.com/products/wireless-rf/lora-core/sx1303ctsxxxgw1
Texas Instruments, TUSB2036 2- or 3-Port Hub for the Universal Serial Bus With Optional Serial EEPROM Interface. URL: https://www.ti.com/lit/ds/symlink/tusb2036.pdf
Molex, 0022112052, KK 254 Solid Header, Vertical, with Friction Lock, 5 Circuits, Gold (Au) Plating, Bag. URL: https://www.molex.com/molex/products/part-detail/pcb_headers/0022112052
Differencies from LimePSB RPCM v1.3
Changes introduction
LimeSDR-PSB RPCM v1.4 implementation is based on LimeSDR-KEY RPCM v1.3 board with the schematic and PCB Layout changes described in this document. The major changes are:
Replaced discontinued SKY13286-359LF RF switches with F2972NEGK. Swapped RF switches RF1 and RF2 ports so RF_SW_TDD polarity inverted.
Added RF couplers and power detectors on both TX channels
Changed discrete PoE solution (NCP1083) to PoE module (AG5712-LPB)
Changed from Type A HDMI sockets to Type D(Micro) HDMI sockets
Replaced clock configuration path jumpers with switches
Altium variant function used in the project
Board size and main components positions remained the same as in LimePPSB RPCM v1.3. New LimePSB RPCM v1.4 block diagram is shown in Figure 11.
Figure 11 LimePSB RPCM v1.4 block diagram
Minor Changes
Minor Changes
Updated diagrams
Cosmetic changes (notes etc.)
Raspberry Pi Connector Changes
Raspberry Pi CM4/5 connector signal changes are:
PCIe LEDs (PCIE_LED_WWAN, PCIE_LED_WLAN, PCIE_LED_WPAN) were moved from RPI connector to I2C GPIO expander number 2 (EXP2).
Newly added RF power detectors (RFPD) were connected to RPI I2C. Their enable signals RFPD1_CONV and RFPD2_CONV were connected to RPI GPIO25 and RPI GPIO26 respectively.
RPI_GPIO3 and RPI_GPIO6 connected to GPIO header (J10).
ADF_MUXOUT moved from RPI_GPIO3 to EXP2 GPB4.
New Raspberry Pi CM4/5 connector changes are shown in Figure 12.
Figure 12 Raspberry Pi CM4/5 connector changes
mPCIe Connector Changes
Added 0R resistor in series to PCIE_UIM4 for mPCIe modules compatibility porpuses. mPCIe connector changes are shown in Figure 13.
Figure 13 mPCIe connector changes
Replaced PCIE_PPS_OUT selection resistors R3 and R8 with analog mux as shown in Figure 14.
Figure 14 mPCIe PCIE_PPS_OUT changes
Miscellaneous changes
Raspberry button was changed to a part with a longer cap (from 3.86 mm to 6.85 mm). Also added option to change button function to RPI CM5 power on/off as shown in Figure 15.
Figure 15 RPI button changes
Changed GPIO header (J10) GND pins 7 and 6 to RPI_GPIO6 and RPI_GPIO3 as shown in Figure 16.
Figure 16 GPIO header (J10) changes
Added test points for Raspberry Pi I2C0 signals (RPI_I2C0_SCL and RPI_I2C0_SDA) as hsown in Figure 17.
Figure 17 I2C signal changes
Added new additional I2C IO expander (EXP2). All signals connected to EXP2 are shown in Figure 18.
Figure 18 New GPIO expander (EXP2)
New GPIO expander was mainly added to control all new muxes added to clock circuitry. But also some already existing signals were added to it:
FPGA configuration signals (FPGA_CRESET and FPGA_CDONE). FPGA_CRESET signal moved from EXP1 to EXP2. Also added posibility to monitor FPGA_CDONE by adding it to EXP2.
PCIE_LED_WLAN, PCIE_LED_WPAN and PCIE_LED_WWAN were disconnected from RPI connector and connected to EXP2.
ADF_MUXOUT was moved from RPI GPIO3 to EXP2 GPB4.
Added Internal U.FL to external SMA connector (EXT2) and renamed old internal U.FL to external SMA connectors to EXT1. New EXT2 SMA connector can be directly connected to on board GNSS module (IC48) RF_IN pin (default) as shown in Figure 19.
Figure 19 Internal to external connectors changes
FPGA changes
Added FPGA_CDONE signal to EXP2 for monitoring purposes. Also 0R was added as a option to disconnect FPGA LED from FPGA_CDONE signal when monitoring by RPI is required. In this case FPGA LED can still indicate CDONE by EXP2 GPB2 pin (FPGA_CDONE_LED). FPGA LED changes are shown in Figure 20.
Figure 20 FPGA CDONE changes
Removed FPGA configuration flash from default BOM as shown in Figure 21.
Figure 21 FPGA flash changes
Increased HW_VER from 0 to 1. And added test point for FPGA I2C0 signals (FPGA_I2C0_SCL, FPGA_I2C0_SDA) as shown in Figure 22.
Figure 22 HW_VER and FPGA I2C0 changes
USB changes
Changed USB header (J31) to Amphenol ICC G823J201240BHR. New header is fully compatible with standard USB header connectors.
HDMI changes
Changed Type A HDMI soctes (J34, J35) to Type D (Micro) HDMI.
Clock changes
Renamed XO_VC signal name to XORF_VC.
Added testpoint for XO DACs outputs as shown in Figure 23.
Figure 23 XO DAC test point
Renamed phase detectors signals names REF_ADF to ADF_RFIN and also REF_CLK_IN to ADF_REFIN to better reflect signals purpose as shown in Figure 24.
Figure 24 Phase detector schematics
Added 0R NF on GNSS_RF_IN net in series with U.FL connector and changed J44 to NF. By default GNSS_RF_IN is connected to INT_TO_EXT2 (SMA) as shown in Figure 25.
Figure 25 GNSS antenna connection schematics
Added pull down resistor for RPI_PIN18 (2.2k) and RPI_PIN16 (2.2k NF). This change fixes Raspberry Pi CM4/5 ethernet connection not working after booting up.
All clock circuitry selection jumper were changed to analog muxes a shown in Figure 26.
Figure 26 LimePSB RPCM v1.4 clock diagram
RFFE Changes
Added RF couplers (HHM22152A2) for channel A and B TX PA RF outputs.
Mentioned RFFE schematic changes are highlighted in Figure 27.
Figure 27 RFFE changes
Due to changed RF_SW_TDD polarity a pull-up resistor was added and pull-down resistor was removed from BOM as shown in Figure 28.
Figure 28 TDD control changes
Added RF power detectors (LTC5587) for channel A and B TX PA RF outputs. RF power detector schematic is shown in Figure 29 .
Figure 29 RF power detectors schematics
Power Changes
Changed discrete PoE solution (NCP1083) to PoE module (AG5712-LPB). New POE shcmatic is shown in Figure 30.
Figure 30 POE module schematics
Removed VCC2P5 circuit from BOM as shown in Figure 31.
Figure 31 VCC2P5 schematics
Changed R135 from 1k to 330R as shown in Figure 32.
Figure 32 Voltage reference schematic
PCB Changes
Layout and PCB changes for LimePSB-RPCM v1.4 board are as follows:
Changes made according to schematic.
Moved 3.5mm A/V socked to the PCB edge and made cutout for socket ring.
Changed tactile switch from 1825027-5 (L=3.86mm) to CT1102V6.85F160 (L=6.85mm).
Changed LED light pipes from SLP3-200-100-F (center line 0.2” (5.1mm)) to SLP3-150-100-F (center line 0.15” (3.8mm)).
Added HDMI and USB3 internal layer trace impedance requirements in specification.
Board size and main components positions remained the same.
Figure 33 LimePSB RPCM v1.4 board top view
Figure 34 LimePSB RPCM v1.4 board bottom view
