LimeSDR XTRX v1.2 Board
Introduction
LimeSDR XTRX v1.2 Board Key Features
LimeSDR XTRX is Small form factor mini PCIe expansion card Software Defined Radio (SDR) board. It provides a hardware platform for developing and prototyping high-performance and logic-intensive digital and RF designs based on Xilinx’s XC7A50T-2CPG236I FPGA and Lime Microsystems transceiver chipsets.
LimeSDR XTRX is a building block for any Massive MIMO configuration from 2Tx2R to 32Tx32R for very high data rate applications. Hence, it could be used in conjunction with any digital processors (ASICs, GPPs and GPUs) of varying level of performance in terms of speed, power dissipation and cost to fit any air interface from narrowband to broadband signals. The board is designed for maximum scalability in terms of the following parameters:
Frequency and Bandwidth: The heard of the board is the Lime Transceiver RFIC (LMS7002) providing frequency flexibility up to 3.8GHz and bandwidths of over 100MHz.
Baseband Interface: A significant level of digital circuitry resides within the LMS7002 and accompanying Xilinx for the implementation of the key physical layer radio functions including filtering, decimation, interpolation and flexible interface such as PCIe and SerDes to name a few.
Figure 1: LimeSDR XTRX v1.2 board top view
Figure 2: LimeSDR XTRX v1.2 board bottom view
LimeSDR XTRX board features:
RF and BB parameters:
Configuration: MIMO (2xTX, 2xRX)
Frequency range: 30 MHz – 3.8 GHz
Bandwidth: 30.72 MHz
Sample depth: 12 bit
Sample rate: 30.72 MSPS
Transmit power: max 10 dBm (depending on frequency)
USB 2.0 controller: Microchip USB3333E-GL
FPGA: board is designed based on Xilinx Artix-7 XC7A50T-2CPG236I FPGAs in 236-ball CSBGA package. Xilinx XC7A50T-2CPG236I features are:
236-pin CSBGA package (10mm x 10mm, 0.5mm)
52160 LUTs logic capacity
2700 Kb Embedded Memory
600 Kb distributed RAM
120x 18x18-bit multipliers
5x PLLs and 4x DLLs
106 IOs
FPGA configuration via JTAG
RF transceiver: Lime Microsystems LMS7002M
EEPROM Memory: 128Kb EEPROM for LMS MCU firmware (optional); 128Kb EEPROM for FPGA data (optional)
FLASH Memory: 256Mb Flash memory for FPGA configuration
Temperature sensor: TMP1075NDRLR
2x Green LEDs
4x GPIOs 3.3V in GPIO connector
1x GPIO in Baseband connectors
Connections:
USB 2.0 (Micro-B) socket
Coaxial RF (U.FL female) connectors
FPGA GPIO 8-pin FPC connector
FPGA JTAG connector (unpopulated)
Mini PCIe edge connector
RF Baseband 15-pin FPC connectors
26.00MHz on board VCTCXO
VCTCXO may be tuned by on board DAC
Reference clock input and output connectors (U.FL and mPCIe)
Board size: 50.8mm x 29.7mm (PCIe Mini card form factor)
Board power sources: USB connector (5V) or mini PCIe (3.3V)
For more information on the following topics, refer to the respective documents:
Board Overview
One of the key elements of LimeSDR XTRX board is the Xilinx Artix-7 (XC7A50T-2CPG236I) FPGA. It’s main function is to transfer digital data between LMS7002M RF transceiver and PC through a mini PCIe edge connector or Serial connection to another FPGA board. The block diagram for LimeSDR XTRX board is presented in the Figure 3.
Figure 3: LimeSDR XTRX v1.2 board block diagram
This section contains component location description on the board. LimeSDR XTRX board picture with highlighted connectors and main components are presented in Figure 4 and Figure 5, respectively.
Figure 4: LimeSDR XTRX v1.2 board top connectors and main components
Figure 5: LimeSDR XTRX v1.2 board bottom connectors and main components
Featured Devices |
IC1 |
RF transceiver |
Lime Microsystems LMS7002M |
Xilinx Artix-7(XC7A50T-2CPG236I) |
USB 3.0 microcontroller |
Microchip USB 2.0 to transceiver chip USB3333E-GL |
Temperature sensor TMP1075NDRLR |
IC16 |
SIM Card Interface NVT4555UKZ |
Configuration, Status and Setup Elements |
X9 |
JTAG chain connector |
FPGA programming connector on the PCB bottom side (compatible with Molex 788641001 connector) |
LED1, LED2 |
Status LEDs |
User defined FPGA indication LEDs |
General User Input/Output |
X12 |
8-pin FPC connector |
Memory Devices |
IC2 |
I²C EEPROM Memory 128Kb (16 x 8), connected to LMS7002M RF transceiver I2C bus |
I²C EEPROM Memory 128Kb (16K x 8), connected to FPGA I2C bus |
SPI Flash Memory 256 Mb (32M x 8) connected to FPGA SPI |
X11 |
USB 2.0 |
USB 2.0 Micro-B socket |
X10 |
mini PCIe |
mini PCI Express Card Edge connector |
26.00 MHz Voltage Controlled Temperature Compensated Crystal Oscillator |
16 bit DAC for VCTCXO (XO1) frequency tuning (default) |
IC11 |
GNSS Receiver module |
IC8, IC10, IC12, IC14 |
Logic level converters |
IC15 |
Analogue switch |
Analogue switch |
X7 |
Reference clock input/output (CLK) |
X6 |
1PPS input |
X5 |
GNSS (active) antenna connector |
IC22 |
Four-output switching regulator LP8758A1E0YFFR |
IC31 |
IC21 |
Linear regulator LD39100PUR |
IC26 |
IC29 |
IC32 |
LimeSDR XTRX Board Architecture
More detailed description of LimeSDR XTRX board components and interconnections is given in the following sections of this chapter.
LMS7002M RF transceiver digital connectivity
The interface and control signals are described below:
Digital Interface Signals: LMS7002 is using data bus LMS_DIQ1_D[11:0] and LMS_DIQ2_D[11:0], LMS_EN_IQSEL1 and LMS_EN_IQSEL2, LMS_FCLK1 and LMS_FCLK2, LMS_MCLK1 and LMS_MCLK2 signals to transfer data to/from the XILINX FPGA. Indices 1 and 2 indicate transceiver digital data PORT-1 or PORT-2. Any of these ports can be used to transmit or receive digital IQ data. By default PORT-1 is selected as transmitter port and PORT-2 is selected as receiver port. The FCLK# is input clock and MCLK# is output clock for the LMS7002M transceiver. TXNRX signals are used to indicate ports direction. Please refer to LMS7002M transceiver datasheet page 12-13. [link] for the LMS7002M interface timing.
LMS Control Signals: these signals are used for the following functions within the LMS7002 RFIC: * LMS_RXEN, LMS_TXEN – receiver and transmitter enable/disable signals connected to FPGA Bank 14 (3.3V). * LMS_RESET – LMS7002M reset is connected to FPGA Bank 14 (3.3V).
SPI Interface: LMS7002M transceiver is configured via 4-wire SPI interface: FPGA_SPI_SCLK, FPGA_SPI_MOSI, FPGA_SPI_MISO, FPGA_SPI_LMS_SS. The SPI interface is connected to FPGA Bank 14 (3.3V).
LMS I2C Interface: can be used for LMS EEPROM content modification or debug purposes. The signals LMS_I2C_SCL and LMS_I2C_DATA are connected to EEPROM.
Chip pin (IC1) |
Chip reference (IC1) |
FPGA I/O standard |
E5 |
xoscin_tx |
LMS_TX_CLK |
Connected to reference clock |
AB34 |
MCLK1 |
LMS_MCLK1 |
L17 |
AA33 |
FCLK1 |
LMS_FCLK1 |
G19 |
V32 |
TXNRX1 |
LMS_TXNRX1 |
V15 |
U29 |
TXEN |
LMS_TXEN |
W19 |
Y32 |
ENABLE_IQSEL1 |
LMS_EN_IQSEL1 |
P19 |
AG31 |
DIQ1_D0 |
LMS_DIQ1_D0 |
J17 |
AF30 |
DIQ1_D1 |
LMS_DIQ1_D1 |
H17 |
AF34 |
DIQ1_D2 |
LMS_DIQ1_D2 |
H19 |
AE31 |
DIQ1_D3 |
LMS_DIQ1_D3 |
K17 |
AD30 |
DIQ1_D4 |
LMS_DIQ1_D4 |
G17 |
AC29 |
DIQ1_D5 |
LMS_DIQ1_D5 |
V16 |
AE33 |
DIQ1_D6 |
LMS_DIQ1_D6 |
J19 |
AD32 |
DIQ1_D7 |
LMS_DIQ1_D7 |
M19 |
AC31 |
DIQ1_D8 |
LMS_DIQ1_D8 |
P17 |
AC33 |
DIQ1_D9 |
LMS_DIQ1_D9 |
N19 |
AB30 |
DIQ1_D10 |
LMS_DIQ1_D10 |
U17 |
AB32 |
DIQ1_D11 |
LMS_DIQ1_D11 |
U16 |
AM24 |
xoscin_rx |
Connected to reference clock thru 0R (NF) |
P34 |
MCLK2 |
LMS_MCLK2 |
W5 |
R29 |
FCLK2 |
LMS_FCLK2 |
W6 |
U31 |
TXNRX2 |
LMS_TXNRX2 |
U5 |
V34 |
RXEN |
LMS_RXEN |
W18 |
R33 |
ENABLE_IQSEL2 |
LMS_EN_IQSEL2 |
W7 |
H30 |
DIQ2_D0 |
LMS_DIQ2_D0 |
W2 |
J31 |
DIQ2_D1 |
LMS_DIQ2_D1 |
U2 |
K30 |
DIQ2_D2 |
LMS_DIQ2_D2 |
U3 |
K32 |
DIQ2_D3 |
LMS_DIQ2_D3 |
V3 |
L31 |
DIQ2_D4 |
LMS_DIQ2_D4 |
V4 |
K34 |
DIQ2_D5 |
LMS_DIQ2_D5 |
V2 |
M30 |
DIQ2_D6 |
LMS_DIQ2_D6 |
V5 |
M32 |
DIQ2_D7 |
LMS_DIQ2_D7 |
V4 |
N31 |
DIQ2_D8 |
LMS_DIQ2_D8 |
V8 |
N33 |
DIQ2_D9 |
LMS_DIQ2_D9 |
U4 |
P30 |
DIQ2_D10 |
LMS_DIQ2_D10 |
U8 |
P32 |
DIQ2_D11 |
LMS_DIQ2_D11 |
U7 |
U33 |
CORE_LDO_EN |
LMS_CORE_LDO_EN |
W17 |
E27 |
RESET |
LMS_RESET |
U19 |
D28 |
SEN |
FPGA_SPI_LMS_SS |
W13 |
SPI interface |
C29 |
SCLK |
FPGA_SPI_SCLK |
W14 |
SPI interface |
F30 |
FPGA_SPI_MOSI |
W16 |
SPI interface |
F28 |
SDO |
FPGA_SPI_MISO |
W15 |
SPI interface |
D26 |
SDA |
LMS_I2C_SDA |
Connected to EEPROM |
C27 |
SCL |
LMS_I2C_SCL |
RF network control signals
LimeSDR XTRX RF network contains matching networks, RF switches, loopback variable attenuator and U.FL connectors (X1, X3 - TX and X2, X4 - RX) as shown in Figure 6.
Figure 6. LimeSDR XTRX v1.2 RF diagram
LMS7002M RF transceiver TX and RX ports has dedicated matching network which determines the working frequency range. More detailed information on LMS7002M RF transceiver ports and matching network frequency ranges is listed in the Table 3.
LMS7002M RF transceiver port |
TX1_1, TX2_1 |
2 GHz - 2.6 GHz |
TX1_2, TX2_2 |
30 MHz - 1.9 GHz |
RX1_H, RX2_H |
2 GHz - 2.6 GHz |
RX1_W, RX2_W |
700 MHz - 900 MHz |
RX1_L, RX2_L |
300 MHz – 2.2 GHz |
RF network switches are controlled via 2.4V logic signals. This is achieved by resistor dividers connected between FPGA (TX_SW, RX_SW1, RX_SW2) and switch control pin (TX_SW_DIV, RX_SW1_DIV, RX_SW2_DIV). RF network control signals are described in the Table 4.
SKY13330-397LF(IC5 and IC6) |
TX_SW/TX_SW_DIV |
P1 |
FPGA 3.3V logic level signal divided to 2.4V logic level. |
SKY13414-485LF(IC3 and IC4) |
RX_SW1/RX_SW1_DIV |
K3 |
RX_SW2/RX_SW2_DIV |
LMS7002M baseband connectors
LMS7002M RF transceiver (IC1)) baseband signals (RX ADC and TX DAC) can be accessed via 0.3mm pitch 15 pin FPC connectors (X13 and X8). RX DAC connector pinout is shown in Table 5. TX ADC connector pinout is shown in Table 6.
Ground |
DAC1Q_P |
Channel 1 quadrature signal differential positive |
DAC1Q_N |
Channel 1 quadrature signal differential negative |
Ground |
DAC1I_P |
Channel 1 in-phase signal differential positive |
DAC1I_N |
Channel 1 in-phase signal differential negative |
Ground |
General purpose input/output (FPGA pin T17) |
Ground |
DAC2Q_P |
Channel 2 quadrature signal differential positive |
DAC2Q_N |
Channel 2 quadrature signal differential negative |
Ground |
DAC2I_P |
Channel 2 in-phase signal differential positive |
DAC2I_N |
Channel 2 in-phase signal differential negative |
Ground |
Ground |
ADC1I_P |
ADC1I_N |
Ground |
DAC1Q_P |
DAC1Q_N |
Ground |
Ground |
ADC2I_P |
ADC2I_N |
Ground |
ADC2Q_P |
ADC2Q_N |
Ground |
USB 2.0 controller
LimeSDR XTRX could be powered and programmed via USB 2.0 by connecting it to micro-B port or mini PCIe connector. USB 2.0 is implemented using Microchip USB3333E-GL transceiver [link]. The controller signals description are shown below:
USB_D[7:0] – 8-bit data interface is connected to FPGA.
USB_NRST, USB_NXT, USB_DIR, USB_STP – interface control signals.
USB_CLK – interface clock. Clock from transceiver is fed to XILINX FPGA.
USB_26M – interface clock. Clock from FPGA is fed to Lime transceiver.
USB 2.0 controller pins, schematic signal names, FPGA interconnections and I/O standard are described in Table 7.
Chip pin (IC19) |
Chip reference (IC19) |
C2 |
RESETB |
USB_NRST |
M18 |
E3 |
DAT7 |
USB_D7 |
C15 |
E4 |
DAT6 |
USB_D6 |
A14 |
E5 |
DAT5 |
USB_D5 |
A15 |
D4 |
DAT4 |
USB_D4 |
B15 |
D5 |
DAT3 |
USB_D3 |
A16 |
C4 |
DAT2 |
USB_D2 |
B16 |
C5 |
DAT1 |
USB_D1 |
A17 |
B4 |
DAT0 |
USB_D0 |
B17 |
A3 |
STP |
USB_STP |
C17 |
B5 |
NXT |
USB_NXT |
A18 |
A4 |
DIR |
USB_DIR |
B18 |
A5 |
CLKOUT |
USB_CLK |
C16 |
A2 |
REFCLK |
USB_26M |
E19 |
Indication LEDs
LimeSDR XTRX board comes with two green indicator LEDs. These LEDs are soldered on the top of the board near the USB Micro-B connector.
Figure 7. LimeSDR XTRX indication LEDs (top)
LEDs are connected to FPGA hence their function may be programmed according to the user requirements. Default LEDs configuration and description are shown in Table 8.
Board label |
FPGA_LED1 |
N18 |
User defined |
FPGA_LED2 |
V19 |
User defined |
Low speed interfaces
FPGA_SPI pins, schematic signal names, FPGA interconnections and I/O standards/levels are shown in Table 9.
FPGA_SPI_SCLK |
W14 |
FPGA_SPI_MOSI |
W16 |
FPGA_SPI_MISO |
W15 |
FPGA_SPI_LMS_SS |
W13 |
IC1 (LMS7002 (IC1)) SPI slave select (FPGA output) |
FPGA_CFG_SPI pins, schematic signal names, FPGA interconnections and I/O standards are shown in Table 10.
FPGA_CFG_CCLK |
C11 |
FPGA_CFG_CS |
K19 |
IC18 SPI slave select (FPGA output) |
FPGA_CFG_D00 |
D18 |
FPGA_CFG_D01 |
D19 |
FPGA_CFG_D02 |
G18 |
FPGA_CFG_D03 |
F18 |
FPGA_I2C1 (temperature sensor, EEPROM, CLK DAC, switching regulator) and FPGA_I2C2 (switching regulator) interface slave devices and related information are given in Table 11.
I2C slave device |
Inteface |
FPGA_I2C1 |
1 0 0 1 0 1 1 RW |
TMP1075NDRLR |
M24128 |
CLK DAC |
1 0 0 1 1 0 0 RW |
AD5693RACPZ |
IC22 |
Switching regulator |
1 1 0 0 0 0 0 RW |
LP8758A1E0YFFR |
IC31 |
FPGA_I2C2 |
1 1 0 0 0 0 0 RW |
LP8758A1E0YFFR |
To debug FPGA design, flash bitstream to FPGA and/or Flash memory JTAG X9 connector is used. It is located on the PCB bottom side (see Figure 5: LimeSDR XTRX v1.3 board bottom connectors and main components) and is compatible with Molex 788641001 connector. JTAG connector pins, schematic signal names, FPGA interconnections and I/O standards are listed in Table 12.
TDO |
W8 |
Test Data Out |
TDI |
W10 |
Test Data In |
TMS |
W9 |
Test Mode Select |
Power (3.3V) |
TCK |
C8 |
Test Clock |
Ground |
GPIO connectors
Four GPIOs from FPGA are connected to 8 pin FPC connector (X12). GPIOS are separated by ground pins. Additional pin is dedicated for power as shown in Table 13.
Power (3.3V) |
GPIO9_P |
H1 |
Ground |
GPIO9_N |
J1 |
Ground |
GPIO11_P |
K2 |
Ground |
GPIO11_N |
L2 |
Clock Distribution
LimeSDR XTRX board clock distribution block diagram is as shown in Figure 8.
Figure 8. LimeSDR XTRX v1.2 board clock distribution block diagram
LimeSDR XTRX board features an on board 26.00 MHz VCTCXO as the reference clock for LMS7002M RF transceiver and FPGA PLLs.
Rakon E6982LF 26.00 MHz voltage controlled temperature compensated crystal oscillator (VCTCXO) is the clock source for the board. VCTCXO frequency may be tuned by using 16 bit DAC (IC17). Main VCTCXO parameters are listed in Table 14.
Frequency parameter |
Value |
Calibration (25°C ± 1°C) |
± 1 ppm max |
Stability (-40 to 85 °C) |
± 0.2 max |
Long term stability (1 year, 3 years) |
± 1 ppm max, ± 2 ppm max |
Control voltage range |
0.5V .. 2.8V |
Frequency tuning |
± 3 ppm |
Slope |
+4 ppm/V |
Analogue switch gives option to select clock source for RF transceiver and FPGA from buffered VCTCXO onboard clock XO1 (CLK_XO) and external U.FL (X7)/mPCIe (X10) sources (CLK_IN_BUFF). Buffered VCXO clock (CLK_OUT) can also be fed to other board using U.FL (X7)/mPCIe (X10)connectors.
The board clock lines and other related signals/information are listed in Table 15. VCCIO_CLK voltage can be selected between 1.8V and 3.3V (default).
Source |
Destination |
CLK_XO |
(VC)TCXO (XO1) |
Analog mux |
Clipped sinewave |
CLK_IN_BUFF |
CLK_IN |
Analog mux |
1.8V |
CLK_IN |
CLK or mPCIe pin 19 |
Level converter |
VCCIO_CLK |
CLK_OUT |
Analog mux |
External |
VCCIO_CLK |
LMS_TX_CLK |
Analog mux |
RF transceiver |
1.8V |
FPGA_CLK |
Analog mux |
FPA |
LMS_MCLK1 |
RF transceiver |
LMS_FCLK1 |
RF transceiver |
LMS_MCLK2 |
RF transceiver |
LMS_FCLK2 |
RF transceiver |
PCIE_REF_CLK_P/N |
PCIe |
mPCIe |
External |
1PPS_IN |
External |
GNSS_1PPS |
GNSS |
USB_CLK |
USB transceiver |
USB_26M |
USB transceiver |
LimeSDR XTRX board communicates with the host system via mPCIe connector. LimeSDR XTRX mini PCIe connector pinout and signals according to the specification is given in Table 16.
Mini PCIe x1 Specification |
LimeSDR XTRX Schematic signal name |
Not connected |
VCC3P3_MPCIE |
Main power input 3.3V (VCC3P3_MPCIE) |
External 1PPS input or GPIO1 or GPIO1N, CMOS 3.3 V |
Ground |
GPS 1PPS output or GPIO2 or GPIO1P, CMOS 3.3 V |
Not connected |
CLK_REQUEST# |
Tied to GND through resistor 330 Ohm |
UIM_VCC |
User Identity Module interface power 1.8 V or 3V |
Ground |
UIM_DIO |
User Identity Module interface data 1.8 V or 3V |
PCI_REF_CLK_N |
PCI Express Reference clock differential pair negative signal |
User Identity Module interface clock 1.8 V or 3V |
PCI_REF_CLK_P |
PCI Express Reference clock differential pair positive signal |
UIM_RST |
User Identity Module interface reset 1.8 V or 3V |
Ground |
Not connected |
TDD TX Enable output or GPIO3N or GPIO4, CMOS 3.3V |
Ground |
CLK_IN |
External clock input 3.3 V |
GPIO3P or GPIO3 (or Pair of TDD TX Enable), CMOS 3.3V |
Ground |
PCIE_PERST# |
PCI Express interface reset |
PCI_TX0_N |
PCI Express interface output differential pair negative signal |
Not connected |
PCI_TX0_P |
PCI Express interface output differential pair positive signal |
Ground |
Ground |
Not connected |
Ground |
SMB_CLK |
Clock output (CLK_OUT) |
PCI_RX0_N |
PCI Express interface input differential pair negative signal |
SMB_DATA |
PCI_RX0_P |
PCI Express interface input differential pair positive signal |
Ground |
Ground |
USB_D_N |
USB 2.0 data differential pair negative signal |
Jumper to GND. Connected by default |
USB_D_P |
USB 2.0 data differential pair positive signal |
PCI_TX1_N |
Ground |
PCI_TX1_P |
Output for LED WWAN (Negative) or GPIO5 3.3 V |
PCIE_RESERVED |
Connected to FPGA (V7) |
Output for LED WPAN (Negative) or GPIO7 3.3 V |
PCI_RX1_N |
Not connected |
PCI_RX1_P |
Ground |
PCIE_W_DISABLE2# |
Connected to FPGA (W3) |
VCC3P3_MPCIE |
Power Distribution
As indicated, LimeSDR XTRX board may be powered via USB port (5V) or mini PCIe edge connector (3.3V). LimeSDR XTRX board power delivery network consists of different power rails/voltages, filters and power sequences. LimeSDR XTRX board power distribution block diagram is presented in Figure 9.
Figure 9. LimeSDR XTRX v1.2 board power distribution block diagram
BOM Variants
LimeSDR XTRX v1.2 project was designed without Bill of material (BOM) variants. Any changes done to BOM are marked as new versions (BOM_VER).
Known issue with LimeSDR XTRX v1.2 not appearing in the operating system. Fixed in BOM version 1.
BOM Version 0 (BOM_VER=0)
Initial board state. No changes in schematics or PCB.
BOM Version 1 (BOM_VER=1)
There were several reports of the LimeSDR XTRX v1.2 not appearing in the operating system. After debugging, a problem was identified: the #PERST reset signal from the host is supplied via a voltage divider, which produced an incorrect voltage level. Our experiments show that after applying the fix described below, the board works properly.
This chapter describes PERST# line divider fix and BOM_VER value increment modification.
PERST# line divider resistors values must be changed (R89 0R, R90 NF) as shown in Figure 10 to eliminate division because FPGA do not properly detected PCI_PERST# states and that caused improper PCI core operation.
Figure 10. PERST# voltage divider
In original Fairwaves XTRXr5 schematic voltage divider (47k in series + 100k to GND) with 3.3V input voltage resulted only 2.245V which does not reach FPGA VIHmin requirement. In Fairwaves schematic this does not caused problem because there PCIE_PERST# directly controlled switching regulator.
For PCIE_PERST# line 0R NF resistor was added. This allows to properly reset PCIE core in FPGA (soft reset, not hard reset), PCIE_PERST# is also connected to FPGA pin. This also allows to properly debug FPGA via JTAG because boar power is not interrupted when PCIE_PERST# line state changes. 0R NF can be replaced with 0R if needed (backward compatible change). In original Fairwaves XTRXr5 schematic PCIE_PERST# was directly connected to first switching regulator EN1, EN2 and NRST.
BOM Version (BOM_VER) value increment
Increased BOM version (BOM_VER) number to 1. This change helps identity fixed boards. From the BOM perspective, the R49 resistor will become no fit, i.e. should be removed as shown in Figure 11.
Figure 11. BOM_VER value increment (BOM_VER=1)
BOM Version 1 (BOM_VER=1) implementation
Although the components are very small (resistors in 0201 package), it is fairly easy to implement the changes described above manually.
To disable PERST# voltage divider remove R90 and change R89 to 0R (or just short it) as shown in Figure 12.
Figure 12. PERST# divider changes (PCB bottom side)
To increase BOM_VER value remove R49 which is located on the top side of the board near TX_B U.FL connector as shown in Figure 13.
Figure 13. BOM_VER changes (PCB top side)
