Firmware Toolchains
RISC-V Firmware Toolchains
For soft RISC-V CPUs (e.g., VexRiscv or PicoRV32), a RISC-V toolchain compiles the firmware (BIOS or application). LiteX simplifies installation and management.
The recommended toolchain is riscv64-unknown-elf-gcc with newlib (no OS), targeting rv32im or rv32ima based on CPU features.
Installation
Use LiteX’s setup script for automatic installation:
./litex_setup.py init install --toolchain riscv
LiteX handles firmware compilation, linker scripts, and Board Support Packages (BSPs) for the selected CPU, embedding the binary into the FPGA bitstream. Override defaults with –riscv-cpu and –cpu-variant options if needed.
