Quick Start
This section describes the prerequisites and basic workflow for building gateware and firmware for the supported boards. The build process relies on several common tools (LiteX, SBT, GHDL, and openFPGALoader) as well as board-specific FPGA toolchains.
Requirements
Before building the project, install the following required tools:
  • LiteX Tag 2025.08 is required. Follow the installation instructions in the LiteX repository. Ensure RISC-V toolchain support is installed together with LiteX.
  • SBT (Scala Build Tool) Installation instructions are available in the official SBT documentation.
  • GHDL Version 4.1.0 is required for VHDL-to-Verilog conversion on some targets. See the GHDL repository for installation instructions.
  • openFPGALoader Version 1.1.1 is required. This tool is used to program supported FPGA devices. See the openFPGALoader repository for installation instructions.
In addition, each board requires a specific FPGA toolchain:
Board-specific FPGA toolchains
Board
Toolchain
Version
Notes
LimeSDR XTRX
Vivado
2022.1
Ensure Vivado is available in $PATH or that its environment has been sourced.
LimeSDR Mini V1
Quartus
23.1
The free edition can be used.
LimeSDR Mini V2
Project Trellis + Yosys and nextpnr;
Diamond
Trellis: latest from source;
Diamond: 3.14
Diamond is required for final bitstream generation.
HiperSDR-44xx
Vivado
2022.2
Exact version required. Also requires AMD patch AR000035576.
sSDR rev2
Vivado
2022.1
Consult the respective toolchain documentation for installation details.
Note
Other tool versions may work, but the versions listed above are recommended to avoid compatibility issues.
Cloning the Repository
To clone the repository and initialize its submodules, run:
git clone https://github.com/myriadrf/LimeSDR_GW.git
cd LimeSDR_GW
git submodule init
git submodule update
Build, Load, and Flash
Gateware for a selected target can be built with the following command:
python3 -m boards.targets.<target> --build
Replace <target> with the appropriate board target module name.
Note
  • Ensure that the required toolchain is installed and configured before building. See Requirements for the toolchain required by your board.
  • Run the build command from the project root directory.
Detailed build, load, and flash instructions for each supported board are provided below:
