Gateware Architecture
The LimeSDR_GW architecture is organized into four top-level subsystems:
HIF (Host Interface) - host connectivity over PCIe or USB
CPU - embedded control and firmware execution
LimeTOP - RF data path and LMS7002 interface
PSS (Periphery Support Subsytem) - board peripherals and support logic
Additional topics:
The design separates the control plane from the data plane. Control and status traffic uses a shared CSR bus, while high-throughput RX/TX sample transport uses dedicated streaming paths between the host interface and the RF path.
Note
This diagram shows the target top-level architecture of LimeSDR_GW. Exact block contents and interconnect details may vary slightly between board targets and implementation stages.
Architectural Domains
HIF - Host Interface Subsystem
The HIF subsystem is the entry point from the host into the FPGA. The LimeSDR_GW framework supports two main high-speed host interfaces: PCI Express (PCIe) and USB 3.0. The interface choice depends on the board, required bandwidth, and host compatibility. PCIe offers higher throughput for demanding streaming, while USB provides simpler integration and broader accessibility.
Its main responsibilities are:
host-visible control and status access,
one or more high-throughput streaming channels,
forwarding control transactions into the internal CSR bus,
forwarding interrupts or events toward the host.
HIF provides a consistent system-level host interface, even though the transport implementation differs between PCIe- and USB-based targets.
USB Interface (FT601)
Boards such as LimeSDR Mini variants use the FTDI FT601 chip for USB 3.0 connectivity. This is wrapped in a reusable LiteX USB core with multiple endpoints:
Control/Status endpoints for configuration, monitoring, and command handling (e.g., GET_INFO, LMS_RST).
Streaming endpoints for RX/TX I/Q data transfer via FIFO.
The core builds on the original LimeSDR USB HDL but fits seamlessly into LiteX’s SoC, using CSRs and Wishbone buses for communication. Firmware manages USB packet processing, FIFO reads/writes, and host interactions.
PCIe Interface (LitePCIe)
Boards such as LimeSDR XTRX use PCI Express, based on the open-source LitePCIe core (at https://github.com/enjoy-digital/litepcie). This enables:
Memory-mapped (MMAP) access via BAR regions for register control and DMA setup.
Streaming (DMA) for high-speed RX/TX I/Q data.
Interrupt support.
LitePCIe integrates closely with LiteX’s SoC, including tools for auto-generating Linux drivers. Firmware handles PCIe command processing, and MMAP interactions.
CPU - Embedded Control Subsystem
The CPU subsystem executes firmware and coordinates initialization, configuration, monitoring, and interrupt handling across the design.
At the top level, it includes:
ISR handling,
board-support logic,
peripheral drivers,
LMS64 communication/control support.
The CPU communicates with the rest of the architecture primarily through the CSR bus and acts as the central control orchestrator for the platform.
LimeTOP - RF Processing Subsystem
LimeTOP is the main RF-facing subsystem. It connects host-side sample streaming to the external LMS7002 digital interface.
the rxtx path,
lms7002_top,
a local Event Manager.
Its main functions are:
RX/TX streaming through dedicated data paths,
LMS7002 digital interfacing,
RF-path control and board-specific integration,
generation of RF-related events and interrupts.
LimeTOP is the main data-plane subsystem. The CPU configures it, but the sample stream flows directly between HIF and LimeTOP.
PSS - Peripheral Support Subsystem
The PSS subsystem groups the lower-speed board-management and peripheral interfaces that sit outside the main RF streaming path.
It typically includes:
GPIO
SPI
I2C
CLK CNTRL
PSS isolates board-specific support logic from the core host and RF data-path logic, which improves reuse across different targets.
Interconnect
The architecture uses three main interconnect mechanisms:
- CSR bus
The shared control/status backbone between HIF, CPU, LimeTOP, and PSS. It is used for register access, status readback, and peripheral control.
- Streaming paths
Dedicated high-bandwidth data paths between HIF and LimeTOP for RX/TX sample transport.
- IRQ/event paths
Event-driven signaling between subsystems. Local Event Manager blocks collect subsystem events and assert interrupts toward the CPU and, where needed, toward the host interface.
External Interfaces
At the system boundary, the architecture exposes the following main interfaces:
PCIe/USB Host
LMS7002 Digital
GPIO Header
SPI Peripheral
I2C Peripheral
These interfaces reflect the two main roles of the FPGA design:
high-speed SDR data transport and processing,
lower-speed board-management and peripheral control.
Board Implementations
The architecture described above is common across supported platforms, while module composition and integration details vary by board implementation.
For board-specific architecture views and implementation details, see:
