UTC Timestamping on LimeSDR‑XTRX
Primary Code References
The logic described below is distributed across the following source files:
Board Target: boards/targets/limesdr_xtrx.py
NMEA Parser: gateware/LimeDFB_LiteX/general/ZDAParser.py
RX Datapath: gateware/LimeDFB_LiteX/rx_path_top/src/rx_path_top.py
System Overview
The timestamping architecture integrates external GPS data with internal FPGA counters to provide accurate packet timing.
- External PPS
Selected in limesdr_xtrx.py from either the GPS header or the SYNC header. Distributed internally as the signal pps_internal.
- GNSS UART
Feeds the ZDAParser module, which extracts UTC date/time. The parser asserts time_valid only when a correct ZDA sentence is received (Checksum OK). Note: The parser ignores the Talker ID and matches strictly on the string “ZDA,”.
- RX Packet Timestamps
The RX path injects timestamps into the packet headers using one of two modes:
Classic Mode: Standard datapath sample counter.
- Mixed Mode: 64‑bit value combining a PPS seconds counter (upper 32 bits) and a cycle counter (lower 32 bits).
[63:32]: Seconds elapsed since the RX Stream Start event.
[31:0]: RX cycles since the last PPS.
- Clock Domain Synchronization
The PPS signal is re‑synchronized explicitly at each consumer to ensure stability:
ZDAParser: Re-synced to the default sys domain.
RXPathTop: Re-synced to the lms_rx domain.
PPS and UART Plumbing
This section details how signals are routed in limesdr_xtrx.py.
Hardware Interconnects
GNSS UART: A UARTPHY instance (baudrate=9600) connects its RX stream directly to ZDAParser.sink.
- Fan-out: The selected pps_internal signal is routed to:
ZDAParser.pps (Used for validity gating).
RXPathTop.pps (Used to reset/increment timestamp counters).
PPS Source Selection
The PPS source is controlled via the CSR periphcfg.PERIPH_INPUT_SEL_0[0].
Value |
Selected Source |
0b01 |
SYNC Header (synchro_pads.pps_in) |
Other |
GPS Header (gps_pads.pps) |
Time Readback (Software Mirror)
The main register bank provides “Current Time” CSRs that mirror the parser outputs for software access:
main_time_min_sec: Fields sec[5:0], min[11:6]
main_time_mon_day_hrs: Fields hrs[4:0], day[9:5], mon[13:10]
main_time_yrs: Field yrs[11:0]
UTC Extraction and Validity
The ZDAParser module handles NMEA sentence processing.
- Input Format
Accepts NMEA ZDA sentences: $–ZDA,hhmmss.ss,dd,mm,yyyy,xx,xx*CS
- Extracted Signals
time_hours, time_minutes, time_seconds, time_day, time_month, time_year.
- Validity Logic
The time_valid signal indicates the reliability of the current timestamp.
On PPS Rising Edge: time_valid is CLEARED. (The previous UTC time applies to the old second).
- On ZDA Receipt:
If Checksum is OK: time_valid is SET.
If Checksum errors: time_valid is CLEARED.
RX Timestamps and Header Insertion
(Logic located in rx_path_top.py)
Timestamp Configuration
The timestamp mode is controlled by the CSR lime_top_rxtx_top_rx_path_timestamp_settings.TS_SEL:
- 0: Classic Mode
Header word PCT_HDR_1 carries the standard datapath sample counter.
- 1: Mixed Mode
Header word PCT_HDR_1 is a 64‑bit concatenation containing both PPS and Clock counts.
Bits
Name
Description
[63:32]
timestamp_pps_counter
Seconds since arbitrary start (increments on PPS rising edge).
[31:0]
timestamp_clk_count
Note
Synchronization: PPS re‑sync and counters run in the lms_rx domain. The PPS rising edge is detected via a small flip-flop chain. This re-synchronization may introduce quantization effects (see Section Edge Cases and Notes).
Counter Logic
The counters operate in the lms_rx domain under the following rules:
Reset State: If TS_SEL == 0 or the internal reset is asserted (int_clk_rst_n == 0), both counters are held at 0.
Active State: If TS_SEL == 1, the counters update as follows:
On PPS rising edge: timestamp_clk_count resets to 0; timestamp_pps_counter increments by 1.
Otherwise: timestamp_clk_count increments every RX clock.
Header Constants
PCT_HDR_0: 0x7766554433221100 (Fixed identifier for XTRX designs).
PCT_HDR_1: Dynamic timestamp value (Classic or Mixed format as defined above).
Software CSR Reference
Key registers for configuring and reading timestamp data.
Function |
Registers |
PPS Control |
periphcfg_PERIPH_INPUT_SEL_0 (Bit 0 selects source)
periphcfg_BOARD_GPIO_OVRD/DIR/VAL (Controls synchro.pps_out)
RX Mode |
Time Snapshots |
Current Time: main_time_min_sec, main_time_mon_day_hrs, main_time_yrs
RX Start: lime_top_rx_time_min_sec, lime_top_rx_time_mon_day_hrs, lime_top_rx_time_yrs
TX Start: lime_top_tx_time_min_sec, lime_top_tx_time_mon_day_hrs, lime_top_tx_time_yrs
(Note: RX/TX start times are captured on the rising edge of fpgacfg.rx_en / tx_en)
Quick Setup Checklist
Verify Build: Ensure the design is built with soc_has_timesource=True (Default for XTRX).
Select Source: Write periphcfg.PERIPH_INPUT_SEL_0[0]: Set to 1 for SYNC Header PPS. Set to 0 for GPS Header PPS.
Enable Mixed Mode: Write TS_SEL=1 in lime_top_rxtx_top_rx_path_timestamp_settings.
- Parse & Compute:
Capture Base Time ( \(T_0\) ): Read the lime_top_rx_time_… registers once after stream starts.
Read Header: Extract the relative seconds count (S) and cycle count (C) from the packet header.
Calculate Absolute Time:
\(T_{packet} = T_0 + S + (C / f_{lms\_rx})\)
Warning
Timestamp Jitter (±1 Cycle)
Users may observe a fluctuation of ±1 clock cycle in the reported timestamps. This is an artifact of the input synchronization logic.
Mechanism: The asynchronous PPS signal is latched into the lms_rx domain via a multi-stage Flip-Flop synchronizer.
Effect: If PPS arrival aligns closely with the clock edge, the synchronizer may resolve the edge one cycle earlier or later between consecutive seconds.
Operational Behaviors
- Counter Free-Run
If PPS is absent while TS_SEL=1, the cycle counter free‑runs and wraps modulo 2^32. The seconds counter does not increment.
- Mode Switching
Switching TS_SEL asserts counter resets.
Transition 1→0: Counters held at 0.
Transition 0→1: Counters resume; seconds counter increments on the next PPS.
- Clock Domain Logic
Mixed timestamp counters are clocked in lms_rx. Ensure the design configuration matches (they do by default on XTRX).
Appendix: Header Decode Example
Scenario:
Header Value: PCT_HDR_1 = 0x00003039_000186A0
Frequency: f_lms_rx = 30.72 MHz
Decoding:
1. Extract Fields:
Seconds = 0x00003039 -> 12345
Cycles = 0x000186A0 -> 100000
2. Calculate Offset:
Offset = 100,000 / 30,720,000
≈ 3.255 ms (after PPS)
3. Final Timestamp:
UTC Time (from CSRs) + 12345s + 3.255 ms
